Old 02-03-2010, 08:59 PM   #1
swayney
Drives: Toyota Yaris SR
How do I remove my cigarette lighter?
Hi all! Nice forums u all have here!
Has anyone had trouble removing their cigarette lighter from the fascia? My fascia is removed but I cant see how to take the lighter out. Any hints would be most appreciated!
swayney is offline   Reply With Quote
Old 02-03-2010, 10:50 PM   #2
tomato
tomato's Avatar
hello UK!
Sorry, I have no idea, my car didn't come with a cigarette lighter.
Old 02-03-2010, 11:22 PM   #3
There are two parts to it. You have to release the outer ring from behind by squeezing the two tabs, and then it will slide out towards you.
Old 02-22-2010, 06:31 AM   #4
Falconeer
Bayou Blue Pearl.
Drives: Yaris 5D Liftback Full Options
how to get behind though? I need to get it out too so I can solder a 3 port one to it with a 500mA USB as well, for charging new type cell phones.
Falconeer is offline   Reply With Quote
Old 02-22-2010, 06:54 AM   #5
Pull off the two vertical trim pieces and then you can pull off the A/C controls to get to the back of the outlet.
Old 02-22-2010, 09:05 AM   #6
swayney
Smile
Thanks for the help! Ive gotta admit I gave up a bought a new one! I think they're slightly different on UK models (well that's the excuse I'm gonna use!)
Old 02-25-2010, 06:27 AM   #7
Falconeer
Bayou Blue Pearl.
Dang that easy! I did get to the AC controls about two weeks ago.
Thanks though.
Old 10-01-2011, 01:39 PM   #8
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
where are these tabs you speak of?
Club SHIFT
Old 02-15-2014, 07:19 AM   #9
jazzyb88
Drives: 2009 Hatchback
Hello,
Sorry to bring up this old thread but I am struggling with the same thing!
I googled some pics of the cigarette lighter to see if i might see where the tabs are but could not.
Here are some pics of the lighter in my car. Does the silver part need to come out first (the lighter assembly) or does the entire socket come out i.e. including the black surround?
Thanks!
jazzyb88 is offline   Reply With Quote
Old 02-15-2014, 11:44 AM   #10
Originally Posted by jazzyb88 View Post
Hello,
Thanks!
http://imageshack.com/a/img811/2315/d96q.jpg
http://imageshack.com/a/img823/1365/9tyy.jpg
http://imageshack.com/a/img32/5594/ookq.jpg
http://imageshack.com/a/img819/3334/56zm.jpg
http://imageshack.com/a/img30/5690/h0o0.jpg
I have a spare lower dash, so I just tried it myself to refresh my memory.
You have to first slide the metal part out of the black part.
To do so (from your pictures):
Release the plastic tabs that hold the metal part to the plastic part by pushing out on the tabs from inside of the lighter, which pushing the metal part from behind the dash. The metal part will then slide out.
Once the metal part is removed you can easily squeeze the tabs on the back side of the plastic part and slide it out as well:
Old 02-16-2014, 10:56 AM   #11
jazzyb88
Hi CTScott,
Thanks once again! I will try this next week once my 3.5mm & USB adapter arrives (pictured below). I think it should fit right in and look neater.
Old 02-16-2014, 11:21 AM   #12
I like that. One of my USB adapters always pops out just enough that my phone doesn't get charged.
Old 02-23-2014, 11:10 AM   #13
jazzyb88
Just wanted to say thanks for your excellent advice. I managed to get it out...only to realise that I actually do need the lighter when using the tyre inflator!
So put it back in and then thought I'd mount the aux and usb ports flush in the glovebox. Drilled a hole, filed away and got it in there, only to realise there was not enough clearance when closing it!
So I ended up using the little holder to mount it on the inside of the glovebox - I would have preferred to flush mount it but wasn't going to make another hole in the thing. I believe there is more clearance on the left-hand side (where all the fuses are on the RHD cars anyway) and should have checked that to begin with...
I suppose you learn as you go along!
Old 05-22-2014, 04:35 PM   #14
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I was just trying to remove mine and discovered the mysterious "OT-9" link in the instrument panel section of the repair manual. I tried pinching the external tabs without success and then went in search of the missing section online. Apparently it doesn't exist!
Big thanks to CT once again!
Old 05-23-2014, 10:15 AM   #15
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
I removed it since I got the car in 2008, put a cheap usb charger and has not been moved since then xD
monchito18 is offline   Reply With Quote
Old 08-30-2015, 11:57 AM   #16
spammenot66
Drives: blue yaris
by any chance does anyone know how to remove the cigarette lighter from the 2012 yaris? Its slightly different. I was able to remove all the panels and access the back. I'm able to disconnect the power from the lighter but i have no idea how to remove the socket out.
spammenot66 is offline   Reply With Quote
Old 01-05-2016, 12:06 PM   #17
retset
Hi CTScott,
I have a Toyota Yaris 2008 Hatchback that looks exactly like the one in the attached Image1.jpg. In order to reach the cigarette lighter and check why it is not working, I removed the left and right trims as you suggested. Then I tried to remove the A/C panel with its contols. The lower part of the AC panel seems easy to remove from its clips but the upper part is not moving outwards by applying normal force. It gives me the impression that I also have to remove the radio receiver. Am I right?
If the A/C panel cannot be removed by applying more force to the upper part, is it possible to remove just the front part of the radio receiver without removing the 4 bolts that fix the radio receiver?
Thanks in advance!
retset is offline   Reply With Quote
Old 01-06-2016, 03:21 PM   #18
jcboy
Drives: Sedan 07
you will have to remove the upper center panel to remove the lower panel. considering you have an integrated stereo, you will really have to remove the 4 bolts.
Cigarette Lighter Fuse stellar DIY / Maintenance / Service 10 01-30-2010 03:08 PM
In-car Cigarette Lighter problem jonr0613 In Car Entertainment + Electronics (audio / video / alarm) 10 10-14-2009 12:16 AM
cigarette lighter assmebly no power? csheller In Car Entertainment + Electronics (audio / video / alarm) 6 09-23-2007 07:18 PM
How to remove the lighter socket? solana_sc DIY / Maintenance / Service 7 12-26-2006 05:47 PM
