![]() Drives: 2007 THREE DOOR 5 SPEED Join Date: Aug 2009
Engine Shudder
My 07 three door five speed has developed what I can best describe as an intermitent engine shudder at idle. I just assumed it was the electric fan cutting on an off but I can feel it throughout the vehicle. I have 65k on her and the mileage is a steady 40-42 mpg.
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
Run a good fuel system cleaner.
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
do you have AC on? when it happens? What does the idle rpm go down to?
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
Interesting you say it has developed the shudder. Mine has done it since new, which mostly occurs during a/c cycling, but can happed as the idle adjusts after coming to a stop. Unless it starts to stall the car I wouldn't worry about it, try a different brand of gas. I've only ever used Chevron in this car and it's always happened, not all the time, not every day, just sometimes.
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
+1
Ill try a quality fuel system cleaner. I usually notice small things like that and Im sure a shudder that violent would have steered me clear of purchasing vehicle. It occurs whent he A/C is not on although Im sure it does it with A/C on. I have one of the digital tachs, so I will document and post what my engine rpm readings are. I guess the general consensus is dont worry about it.
wonder if changing out the plugs could solve that . Just because they're iridium plugs that are able to last for 100,000 miles doesn't mean squat . I had the iridium plugs changed in a 2000 COROLLA at around 75,000 miles and gained better pickup along with some gain in mileage .
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
| The last gas question | Tonavi | DIY / Maintenance / Service | 56 | 04-27-2009 08:40 PM |
