Old 02-21-2010, 11:44 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Compression Question...
*For d ones who don't know* I own a yaris 2001 with a 1NZFE turbo engine.
I had seen many threads showing built 1NZFE engines for turbo through out my research and I noticed that many of them use CP pistons or other brands with a compression ratio of 9.5:1.
Well mine seems to be the only 1NZ with 8.5:1 compression arias pistons...
From the beginning of my project I always had\have issues in slow running and idling so I am suspecting if these issues might be due to the lower compression
Parmas is offline   Reply With Quote
Old 02-22-2010, 01:12 AM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
What happens if you raise you idle a little? Maybe you have other issues, like valve problems?
Old 02-22-2010, 01:30 AM   #3
mine are 9:1 -- I'm pretty sure. Your car should idle ok.
Old 02-22-2010, 04:36 AM   #4
Parmas
Parmas's Avatar
Idle is fluctuating between 1000rpm till 1500rpm especially when cold starting. Sometimes it reach 1800rpm so we didn't try to raise idle since its already too much for me.
When slowly pushing the gas from 2000 till 3000rpm, the engine knocks several times. After 3k rpm kicks in VVTI & boost and the engine shows us real performance till 6500rpm.
I know some should say it's a tuning problem and maybe it is... but it's really hard to get it stable within 2K-3K rpm range especially when you try to lean it out more than 10.5 AFR
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Feeler question? Cutie Pie #2 Items for Sale by private party 4 08-18-2009 04:03 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
dealer trade-in payoff question.. kapo New YARIS Purchase Forum 1 07-16-2007 10:27 PM
