Equalizer Question
Which would be the "main in " From the Source Unit if you have the following outputs: Front, Rear , Center, and Sub
High speeds are fun...
Drives: 07' Polar White sedan Base Join Date: Nov 2008
well brand would help my friend. what brand is it of the head unit? i have a sony Xploid head unit and it has a setting for it to set it as "SUB OUT" or "REAR OUT" and it has only one set of output RCA jacks. have you checked that?
Mine is a JVC DVD player and it has all of the above, Front Rear, Center and Subwoofer outputs.
Model number is : KD-AVX2
Audio Junky
Brand doesn't matter.. the "Main in" thing refers to the source... is the main an Ipod, a Sat Radio, or a deck... The eq sounds like it functions similar to a home theater receiver... pick what you want.
would be the front RCA's (from your deck)... so you have a 5.1 deck? do you plan on eq-ing just the fronts? parametric or graphic, how many channels total do you have (on the eq) |
Clarion EQS746 1/2 DIN Graphic Equalizer with Built-in Crossover
Product Description 7-Band Graphic Equalizer 6-Channel / 7 Volt RCA Outputs (Front/Rear/Subwoofer) Adjustable Master Volume Level Control Adjustable Subwoofer Level Control 2-Channel RCA AUX Input with Adjustable Gain Selectable 12dB Low-Pass Crossover (60Hz or 90Hz) Gold Plated Terminals Dimensions:7"(W) × 1"(H) × 4"(D) Another question is the 7 Volt RCA Outputs will effect my amp in what way ? I believe the Output from the Player is around 2.5V And i'd like to use the eq to Run my Front, Rear and Sub. <br> <br>
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 03:57 AM |
| So question here abt hatchs in general | Jem_hadar | General Yaris / Vitz Discussion | 12 | 01-06-2009 03:06 AM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
