Old 03-03-2010, 06:57 AM   #1
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Clicking noise when jerking steering wheel side to side/hit bumps left side
I noticed this a couple days ago. When i jerk my steering wheel side to side real quick, before it starts moving the wheels, i hear a clicking noise like something is lose. Also when my left (driver side) wheel hits a bump i hear that noise. The noise does not happen while i turn. So i dont believe its my axle. I hear the noise coming not from the wheel/knuckle, but more inside near the middle of the engine bay. I have also noticed a difference in my alignment. Might it have something to do with the tie rod? I have about 18k miles, and havent had any accidents/work done to that side of my car. I did however hit a dip pretty hard the other day and i am thinking that may have caused it. Thanks for any insight on this issue in advance.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 03-03-2010, 07:31 AM   #2
lowsushi
Akiba Otaku
lowsushi's Avatar
Drives: 2010 Yaris 5dr
Send a message via AIM to lowsushi Send a message via Yahoo to lowsushi
Now is this a REAL bad clicking? I have a 2010 that I bought in Dec, and I hear some noise when I turn out of my garage (to the right), or hit a speed bump in my complex (speed limit 10) but it doesn't really sound bad to me. I had an alignment after I lowered my car and I can't remember if I heard the noise before I lowered it or not.
Might just be a normal noise that we are not accustomed to?
PS3 Trophies
lowsushi is offline   Reply With Quote
Old 03-03-2010, 08:07 AM   #3
eii
Rides canyon walls
eii's Avatar
Well its loud enough to alert me cause I've never heard it before. I dont know too much about tie rods so I dont know what could be wrong with it or if this is causing my problem. I definitley noticed my alignment went off and im not sure if its just my imagination but i swear i feel like my wheel/s are changing directions on their own like something IS loose.
Old 03-03-2010, 10:08 AM   #4
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
sounds like you damaged a tie rod.. order a new set from toyota (they're not expensive) and take them when you take the car to get aligned. it's really not a big deal.
Originally Posted by xnamerxx
you nailed it sir.
Old 03-03-2010, 12:07 PM   #5
eii
Rides canyon walls
eii's Avatar
Cool, yeah the parts arent that expensive (whooooooo). Hopefully its just that, I have a ton of other things to fix on my car right now :)
Old 03-22-2010, 10:59 AM   #6
eii
Rides canyon walls
eii's Avatar
Old 03-22-2010, 02:34 PM   #7
bronsin
bronsin's Avatar
How did you discover its the rack?
Old 03-22-2010, 03:39 PM   #8
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
had this issue it was my shock though it was leaking..changed it under warranty..
Old 03-22-2010, 07:46 PM   #9
eii
Rides canyon walls
eii's Avatar
Humming noise when turning the steering wheel!! Help?? mhkritzinger DIY / Maintenance / Service 7 09-28-2009 09:27 AM
