Old 03-18-2010, 08:12 PM   #55
docB
Drives: '09 Yaris Sedan
Originally Posted by Twistoffate0817 View Post
When does the Northeast switch over to summer gas?
HA Ha ha
We don't have summer and winter blends any more. All the gas is cut with ethanol all year round. The alcohol just cuts your milage and raises the oil company profits. The environmental benefit just doesn't make this a good proposition. Flex fuel vehicles are as big a joke as HEVs.
doc
docB is offline   Reply With Quote
Old 03-18-2010, 08:15 PM   #56
docB
Originally Posted by captainm27 View Post
I know every car suffers MPG drops in the winter. But why is that? Is it because of the winter blend type of fuel being used? Or does an engine use more gas to stay warmer during the coler months? I drive my Yaris the same gentle way I do in the winter as I do during the warm spring days (with the exception of snow storms, etc.) I never see my RPM's going so much higher to suggest using more fuel. Does the engine use more fuel, even though it is keeping the RPM's at the same levels? Or is RPM just not a good indicator of how much gas is being used?
Everything needs to warm up. Oil, grease, water, and the passengers. All that heat plus wipers and defrosters use up extra fuel. The DEF mode for the HVAC runs the air conditioner, too. The snow on the road offers a tremendeous drag that needs to be overcome.
doc
Old 03-18-2010, 08:17 PM   #57
docB
Originally Posted by b_hickman11 View Post
Your engine likes warm and hot air to be brought into it from the intake. The hotter it is outside, the better mpg's you will get. I recorded my best mpg on a day it was 105+ degrees outside.
Was this mileage determination made with a Scan Gage or be refilling the tank?
doc
Old 03-19-2010, 12:44 AM   #58
b_hickman11
Drives: 08 Sedan
doc
By refilling the tank with the last bar started blinking and divided miles driven by amount of gas filled.
Old 03-19-2010, 12:44 AM   #59
b_hickman11
Drives: 08 Sedan
HA Ha ha
doc
Still have it here in Texas....
Old 03-19-2010, 01:08 AM   #60
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Summer and winter blends aren't about ethanol vs. no ethanol. It's the boiling range of the gasoline part. In the winter they use a lot more butanes and pentanes, which give more vapor pressure for easy cold starting. In the summer the butanes and pentanes are way down, and there are more of the heavier, high boiling hydrocarbons to reduce vapor locking and evaporative emissions.
Old 03-19-2010, 01:10 AM   #61
Hershey
doc
would think the cold could affect wheel bearing grease as well . Making for more resistance . No ?
Old 03-19-2010, 01:21 PM   #62
Uber_Otter
Uber_Otter's Avatar
Drives: Black XA not yaris but close
Dallas just switched back over to summer gas. I think. Got a 3 mpg gain on my last tank. Drove the same. Maybe they use Daylight savings as the cutover.
Uber_Otter is offline   Reply With Quote
Old 03-19-2010, 02:39 PM   #63
Yaris Hilton
Smile
Might've had a difference in your fill levels at the beginning and end of that tank, or a different driving profile. It's a little early for the change, I think. (It's still Winter.)
Old 03-20-2010, 11:49 AM   #64
docB
It is great to track mileage. The big thing that really tells the whole picture is to keep track of all the fuel that goes into the tank and divide that into the mileage on the odometer. Then the amount you got back into the thing on a refill is a moot point. I made a small excell spread sheet. I keep track of the date, the odometer reading, the quantity of fuel (all the decimal places on the pump), the dollar amount and where I got it. If there are odd circumstances, I keep a side note. I track maintenance items here, too. The sum of the cost of the fuel is tracked along with the total gallons used. This is the number that I divide into the total miles on the car. I update the total fuel economy at the government EPA your mileage site. I have been over 39 mpg since I picked up my cash for clunker the last day of August last year. The max was a little over 44mpg and the low is probably in the high 20s. By the way, a 1994 Ford Escort Wagon 5-speed I bought new average just over 35 mpg over the time I owned it. I don't place a lot of faith in the instantaneous readings the cars provide. I think by brothers full size Dodge pick-up could only get 99mpg on a railroad flat car...lol
doc
Old 03-20-2010, 08:16 PM   #65
b_hickman11
Drives: 08 Sedan
doc
Sounds like a lot of extra work just to find your mpg.....
Old 03-20-2010, 08:49 PM   #66
BailOut
Steals terrorist's lunch
BailOut's Avatar
That's because he's tracking more than just MPG.
- Brian
Share the Road
Old 03-21-2010, 05:46 PM   #67
b_hickman11
Drives: 08 Sedan
Sounds like he needs to track what winter gas is.....
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
Do you get about 4 MPG less during winter ? paraganek Fuel Economy Forum 24 05-18-2009 10:52 AM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 06:48 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 09:07 AM
