Old 03-24-2010, 02:03 PM   #1
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Hard wired USB charge port?
Rather than use a cigarette lighter USB charger, I'd like to hard wire a USB port (or two) into my Yaris console. Has anyone found a clean solution for this? Something that you can flush mount to a flat panel would be great. I'd like the output of the port to be 1A (1000mA).
Thanks all!
-S
Old 03-24-2010, 02:41 PM   #2
darthbauer
Not really here...
darthbauer's Avatar
I'm just going to get a different head unit for my car that has a built in one. Like this one from Pioneer.
http://www.pioneerelectronics.com/PU...rs/AVH-P3200BT
Liberate Tutemet Ex Infernis.
Old 03-24-2010, 02:43 PM   #3
schleppy
I love momentum.
schleppy's Avatar
That solution is a bit more pricey than I'd like :D
Old 03-24-2010, 02:48 PM   #4
Can't you just take that, snip off the lighter end, and wire it in?
Sorry electronics is not my strength.
Old 03-24-2010, 02:50 PM   #5
schleppy
I love momentum.
schleppy's Avatar
You can, yes, but I'd like a slightly "cleaner" install. I'm also not sure what sort of amperage that would push to the connector. Maybe CTScott will chime in and enlighten us :D
Old 03-24-2010, 03:18 PM   #6
Snappy
Drives: 2 Yaris Hatchbacks
Again, not quite what you asked for, but pretty unobtrusive:
Belkin Micro USB Charger (flush fitting lighter socket.)
http://www.belkin.com/IWCatProductPa...duct_Id=489424
Snappy is offline   Reply With Quote
Old 03-24-2010, 03:20 PM   #7
schleppy
I love momentum.
schleppy's Avatar
Not exactly what I wanted, but that is a very nice alternative. Thank you!
Old 03-24-2010, 03:25 PM   #8
BailOut
Steals terrorist's lunch
BailOut's Avatar
http://www.yarisworld.com/forums/showthread.php?t=9431
- Brian
Share the Road
Old 03-24-2010, 03:27 PM   #9
schleppy
I love momentum.
schleppy's Avatar
Not quite as clean a solution as I'd like, but that's definitely the right track. Thanks!
Old 03-24-2010, 04:21 PM   #10
darthbauer
Not really here...
darthbauer's Avatar
There are different head units that are cheaper that I have seen with a USB port.
Old 03-24-2010, 04:22 PM   #11
schleppy
I love momentum.
schleppy's Avatar
I know, but I like the Alpine deck I'm currently using.
Old 03-24-2010, 04:32 PM   #12
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
take a look at the fuse for the cigarette lighter for a clue as to if a 1 amp charging source is possible. If the fuse is 1 amp, you should be able to draw 1 amp from it for an hour or two without a problem. If the fuse is greater than 1 amp, you should be able to draw 1 amp from it with no problems at all.
You could always wire in your own fused circuit using 12awg wire, which would be good for say 20 amps if you wanted. You could then run any additional items off that in the future too. www.partsexpress.com has one right now for $2.50
then you just have to search through a compnay like www.digikey.com or www.mouser.com to find a surface mount female USB port.
i'm sure if you did a google search for the pin outs for a USB port you could find instructions or an image that would show which each contact does. I once knew what they were... I want to say that they are 5volt & 7volt lines usually, but not positive... make sure that your device you are charging can accept 12v in, you wouldn't want to run a 12volt circuit to a device that could only handle 7v.
Old 03-24-2010, 04:37 PM   #13
schleppy
I love momentum.
schleppy's Avatar
Thank you talnlnky, that was very helpful! The "surface mount female USB port" is the keyword I was looking for. If I can find that I can wire up the rest.
Getting warmer: http://www.amazon.com/Cable-Waterpro.../dp/B000AA85BG
DIY Powered USB Ports BailOut DIY / Maintenance / Service 27 02-22-2017 10:17 AM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 10:06 AM
