![]() Drives: 2009 and 2010 Yaris Join Date: Feb 2010
'10 Yaris Cruise Control
I had both a '09, 5dr. and '10 sedan Yaris, After my son totaled my '09 we bought another '10 5dr Yaris. I just put in the Cruise in the '10 5dr. The only difference is where the cruise on and set instrument panel lights are located. They are now located on the left side verses being above the fuel gauge on the right. Note neither car had rpm gauge option.
I have an '10 5 door also and I after reading the DIY, I noticed the indicator lights are exactly where yours are.
Did you install the OEM parts or did you install the 2 button / 4 button set up? I'm going to try the 4 button set up and install them in the center console by the e-brake handle. Did you run into any issues on your install? If all goes well, I'm planning on doing this: |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
that is quite a lot of real estate used up for cc
functions are [on/off] [set -] [cancel] [res +] |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 02:57 PM |
| Throttle position used as cruise control? HELP | Appalachian Trail 2007 | Performance Modifications | 11 | 11-09-2008 11:10 PM |
