Old 04-08-2010, 04:18 PM   #19
Rick
Drives: '08 Yaris LB 5M
Another reason for dielectric grease inside the plug boot (besides a gas and moisture tight seal) is to prevent the plug boot from becoming more or less permanently bonded over time to the spark plug insulator. It's just another little detail that separates the craftsmen from the workmen.
Rick is offline   Reply With Quote
Old 04-11-2010, 05:35 PM   #20
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Originally Posted by 127.0.0.1 View Post
don't put dielectric grease inside the plug wires.
the grease doesn't conduct electricity, and for a large pulse
like a plug has, it can restrict it a bit (less metal-metal contact)
and overheat the wires.
dielectric is best for low voltage...like ordinary 12v or 5v electrical connectors
elsewhere in the vehicle that may be splashed with water, snowed or slushed on...
Should people use anti-seize compound between the threads and the head?
Old 04-11-2010, 06:12 PM   #21
127.0.0.1
there is a lot of conductive metal in most anti seize
plus there is much more metal-metal due to the
available surface area of the threads
Old 04-11-2010, 10:37 PM   #22
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Yes, you should use it. You don't want a stuck plug.
Where can I get iridium spark plugs??? fidgell Canada 4 03-01-2010 01:10 AM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-02-2009 12:50 AM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 03:07 PM
Where do I buy ngk iridium tip 7 heat spark plugs? PETERPOOP Performance Modifications 23 03-08-2009 09:34 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 02:53 PM
