Old 01-06-2007, 09:47 AM   #19
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Old 01-06-2007, 11:16 AM   #20
acrbill
Drives: Polar White Hatch
The question of the hour is what type of bulb that headlight uses. If you can get away with buying those headlights and using an ebay HID kit that would be sweet. If you had to buy all the HID stuff from Toyota that would be super expensive and probably not worth it.
http://home.comcast.net/~job0b/ywsig.gif
ChinoCharles Intake supporter.
acrbill is offline   Reply With Quote
Old 01-06-2007, 02:48 PM   #21
SmellyTofu
好多人&
Drives: .
If you actually look carefully, there's 2 bulbs in there. One for low beam, and below for high beam.
If you feel buying Ebay stuff is worth the effort for additional glare to oncoming cars, then by all means go for it.
SmellyTofu is offline   Reply With Quote
Old 01-06-2007, 06:31 PM   #22
Violin
Violin's Avatar
You can pick up new Philips D2S bulbs for about $30-40 each. They'll last about 3,000 hours.
Old 01-06-2007, 11:42 PM   #23
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
The biggest problem I see with transplanting some of these parts is the fact that Japanese cars drive on the other side of the road and drivers side is on the right. On the under steeringwheel tray, i'm not sure it would fit perfectly, as the panel that replaces it on US cars may actually be a mirror image shape, and if the panels aren't symetrical, it nixes a plug and play approach. If I was able to get one of the Japanese panels, there's always a possibility I could use it and the US panel to make a US-fit panel with the Japanese storage tray in it, possibly make several out of fiberglass. As for the underseat tray, besides having to make up the bracketry to get it to fit, you'd also need to find a way to keep it from catching on any of the passenger sensor wires. Finally, the headlights, they're problematic for two reasons, they're made for cars that are RHD, the beam pattern will be completely improper for US roads, as the upward spike in the cutoff will point toward oncoming traffic, blinding them, and pretty much assuring you will be bright-flashed by other drivers and probably pulled over for failure to dim headlights. Unlike projectors, this isn't a simple fix like a swapped shield, Reflector patterns are near impossible to modify without replacing the entire thing. The other problem with the JDM headlights is the lack of the Amber reflector, US Law mandates an amber reflex reflector on the front side of a motor vehicle, and while some jurisdictions really don't enforce this, you're just asking for trouble if you ever move to or drive through one that does. We could probably could have gotten away with cleared headlights if only Toyota had made those side turn signal repeaters with a reflexive amber shell, that would have satisfied the requirement for a side front amber reflector.
paultyler_82 is offline   Reply With Quote
Old 01-06-2007, 11:59 PM   #24
acrbill
The glare is created by the headlight housing not the bulb. If the housing is an HID housing then any HID should have the same pattern.
Old 01-07-2007, 12:00 AM   #25
acrbill
Look at that website. The cars they show are LHD. Thats a Taiwan Toyota site.
Old 01-07-2007, 05:04 AM   #26
paultyler_82
Wow... so they are... I wasn't even paying attention, well in that case, all parts (except the underseat shelf, because of the wires) should fit fine... this has got to be the only toyota global site I didn't check when I was looking for parts unavailable on US models... There is still the matter of the amber reflectors, of course, but that's minor, and most people won't care, just watch where you're driving, some jurisdictions are pretty tough on DOT/SAE regulations. Even the HIDs will be fine, Taiwan drives on the right, like us, I've got some of the Taiwanese model Cefiro one-piece headlights on my I30, much better than the separate headlight/corner signal units stock on the I30, plus even with a halogen reflector, it has a fairly definite cutoff, I think Taiwan uses the ECE standard for thier headlights, good sharp pattern, better than the blurry or spotty (in halogen applications) DOT beam patterns
Old 01-07-2007, 06:41 AM   #27
SmellyTofu
好多人&
Drives: .
Link us a place from Ebay where I can buy a HID housing from Taiwan (being a LHD country)?
Old 01-08-2007, 12:56 AM   #28
Billstein
Whew Who..
Billstein's Avatar
Drives: 2 Yaris Hatchs and Tacoma
Ah I put new lamps in my lower front they are 5w driving lights
"HERS"2007 Yaris Hatch BlazzingBlue Power everything Sirius Radio FullSyn Oil 50% tint windshild35% front 5% rear Keyless Entry Alum TRD Shift Knob
TRD Exh Tip 17" racing harts/Falkins TRD Cold Air Intake
"HIS"2007 Yaris Hatch MedSilverMetallicPower PQ Package 17" Wheels Spoiler TRD ExhTipStiletto100 Radio Armrest 50% tint windshild 35% front windows 5% rear Aluminum TRD Shift Knob Keyless Entry VIP Alarm TRD Cold Air Intake
Billstein is offline   Reply With Quote
Old 01-08-2007, 02:20 AM   #29
paultyler_82
Eh... doubt you'll find any on Ebay, you'll more than likely have to find an importer that can buy them direct.
Old 01-08-2007, 01:34 PM   #30
mutatio
Drives: Flint Mica AT Sedan
so the bulbs light up the tray? new thread anyone? ;)
mutatio is offline   Reply With Quote
Old 01-08-2007, 08:47 PM   #31
Pars
Drives: 07 Yaris Liftback
So, does this under seat tray actually exist? Cause I haven't seen any photos.
Pars is offline   Reply With Quote
Old 01-09-2007, 12:54 AM   #32
paultyler_82
This right here, from the first page
Originally Posted by Adriaan View Post
is a pic of the tray.
Old 01-09-2007, 09:02 AM   #33
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
The leather is bad ass!
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 01-09-2007, 09:05 PM   #34
sewid
Aussie Yaris Nut
Drives: AUSDM Yaris YRS
Australian delivered Yaris didn't get this because they put the jack under the passenger seat.
sewid is offline   Reply With Quote
Old 01-09-2007, 11:27 PM   #35
SmellyTofu
好多人&
Drives: .
sewid, look again because there is one under the passenger's seat below the fore and aft adjustment for the seat.
Old 01-09-2007, 11:51 PM   #36
sewid
Aussie Yaris Nut
Cool. I hope so. I just looked yesterday and saw a jack. I'll have to look more closely........
