#91 |
![]() ![]() Drives: Yaris 08 Join Date: Mar 2009
The bolt is M6 X 1.00 (metric) and the Length is 75mm aprosimative (3 inch)
I search for to find a dealer |
#92 |
I have install mine today. I have use the original gasket for intake to spacer, and for spacer to TB just a silicone. Bolt is M6 X 1.00 3 inch . Result, idle fix at 600 RPM and maby a litle diffrent at mid range but at cold start, engine go at 2900rpm.
#93 |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
I picked up the M6 x 1.00 x 75 bolts today and will hopefully be tackling this soon
#94 |
Damn. I should have been watching this forum. Is there a way I can still get one of these? Payment can be immediate.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
#95 |
#96 |
Someone post up a picture of the installed piece.
#97 |
i installed my spacer and TB today, the idle settle at like 6k rpm but my check engine ligth came on and it has not come off, any ideas what did i do wrong. I did unplug the batt for like an hour before i plug it back in.
#98 |
A 6K RPM idle is extremely high. Something's definitely wrong there. Not sure what the problem could be, but you may want to unplug the battery for longer to make sure the ECU completely resets itself.
#99 |
sorry 600 rpm
#100 | |
Drives: Yaris 3dr Hatchback Join Date: Mar 2010
Will this give a HP gain, or any sort of response difference?
#101 |
im going to dyno my car soon with the spacer and w/out as soon can in school
#102 |
Sweet let me know how it goes, I am gonna try to get one on the next order if I can.
#103 |
600 RPM is within the normal idle (I have ~500 RPM myself with the 1ZZ TB). The CEL should go away after a few trips, but I can't say for sure.
#104 |
ill wait a couple of days to see if it clears if not ill unplug the batt for like 6 hours
#105 |
1st mod project at 35
Drives: 2008 Yaris Join Date: Apr 2010
Is there any way one could get the prints on this part? It doesn't look that hard to make. Even with the o-ring.
#106 |
do you gave aply silicone between spacer and throttel
#107 |
Chris
Drives: 2007 Yaris S Join Date: Dec 2009
Is there a spacer for the 1NZ-FE?
#108 |
![]() ![]() ![]() Drives: 07 Sedan - 5 Speed Manual Join Date: May 2006
| Dash destroyed in electrical fire. | purpleminx | General Yaris / Vitz Discussion | 79 | 06-12-2009 03:53 PM |
| [Recovered] Group Buy for Australia #1 (Badges) | harveyjai | Australia | 9 | 12-13-2008 03:59 PM |
