![]() Drives: Yaris 2003 Join Date: Apr 2010
Hi,
The engine on my Yaris starts to shake when in idle and as I start to accelerate I can feel the engine sputtering. Any suggestions before I take it to the dealers.thanks |
Half a Bubble Off Plumb
Is the Check Engine light on? If so, you need to get the code. Is this car at a high enough mileage to need spark plugs?
Thanks Yaris Hilton,
No check light on, car has roughly 60,000 miles on display, I don't have the service history so not sure when the spark plugs were last changed? |
![]() ![]() ![]() ![]() Drives: 2006 yaris Join Date: Oct 2008
I think the spark plugs are supposed to be good for 100k but don't quote me. I feel like I read that somewhere.
At least the U.S. models have 100,000 mile iridium plugs.
Learn to Relax
If it's 2003, it might have platinum plugs and need to be replaced at 50,000 miles. It could also be clogged injectors.
Yeah, I think the plugs were platinum in those days. My daughter's 2001 Echo started acting that way as it was getting close to 100,000 miles with those 50,000 mile plugs in it. Changed the plugs, cleared the random misfiring code, and everything was fine.
mounts maybe ?>
![]() ![]() Drives: 2009 toyota yaris 1.3 sedan Join Date: Apr 2010
spark plugs or something's wrong with the electricity goin' to the engine ...
any mods which require much electricity u installed may affect the battery life and therefore u may need to check on the battery |
Thanks everyone,
I will check the plugs and battery, How do you un-clogg the injectors? |
Cheers Bluevitz-rs I will try this
the '08 sedan idles rough when at redlight , etc.. When I put it in neutral it's less noticeable . Put TECHRON with a fill of 93 octane to no avail .
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 04:07 PM |
| Toyota Yaris Engine Map | wariss | Performance Modifications | 5 | 03-15-2009 01:21 PM |
| Is the Yaris engine a little rough? | thomasward00 | General Yaris / Vitz Discussion | 23 | 04-30-2007 01:17 PM |
