Old 04-27-2010, 06:42 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
Exclamation Alternator Pulley Question
Can anyone tell me if the alternator pulley from a Scion xA/xB will fit on the Yaris alternator? It seems they take different alts, but I'm wondering if the pulleys are the same.
NST sells an overdrive pulley for the xA/xB, which has the same belt size and offset as the Yaris, so I'm wondering if it would work on the Yaris alternator?
Old 04-27-2010, 06:45 PM   #2
MGargano
Nevermind...just got word back from NST that the center bore size is different between the xA/xB and the Yaris. At least now I have a definite answer.
Has anyone had luck finding an overdrive alternator pulley for the OEM Yaris alt?
Old 04-27-2010, 06:47 PM   #3
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
Out of curiosity...what exactly will that accomplish? More power output from the alt?
Old 04-27-2010, 06:48 PM   #4
MGargano
Supposedly, higher/more consistent output when the engine is idle/at low RPM
Old 04-27-2010, 07:11 PM   #5
MGargano
If anyone's interested, I was able to custom order a 20% overdrive alternator pulley from Mike at NST.
Combined with a 10% underdrive crank pulley, the 20% overdrive alt pulley should get me a 10% gain on the alt.
The way he and I figured it, using a 10% overdrive alt pulley & 10% underdrive crank pulley would've been pointless, as the two would cancel each other out and I'd end up in the same place I'm at now.
I'll have a definite answer in 5-6 weeks.
Old 04-27-2010, 07:15 PM   #6
suckerface
#1 Lemming
suckerface's Avatar
I should have prefaced that I'm just learning about cars. So with that being said, higher/more consistent output will get us....better battery life? better performance on after market electronics (amps and such)?
Sounds like a simple and cost effective mod, as long as the results are effective anyways.
Old 04-27-2010, 08:14 PM   #7
MGargano
On my car, for some reason, the voltage runs ~14.1 while I'm moving at a decent speed. At idle/lower RPMs, the voltage drops to ~13.5, with or without the amplifiers, etc on.
I'm hoping this overdrive pulley will allow for a higher/more consistent voltage output at idle/lower RPM.
Old 04-28-2010, 12:59 AM   #8
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
You have a lot to learn.
Old 04-28-2010, 06:54 AM   #9
MGargano
Old 04-29-2010, 03:43 AM   #10
yaris-me
Learn to Relax
You don't need to change anything, unless you're increasing the electrical load at idle, in which case it would be better to put a higher output or larger alternator. Basically, the alternator will increase output with increase in demand. In other words it is load sensitive.
That being said, the xB has a larger alternator for increased output for audio upgrades. That was anticipated because it is geared for the youth market.
Old 04-29-2010, 07:21 AM   #11
MGargano
The problem I'm having is that the dip in voltage occurs with or without the presence of a load. Mine seems to fluctuate based on the car's speed/RPM, rather than what I'm drawing.
Basically, the alternator will increase output with increase in demand. In other words it is load sensitive. :smile
I really appreciate your input, especially since I'm just learning about this myself, but I haven't not found this to be the case. Even when I turn everything off (HIDs, amplifiers, etc), the voltage drops (sometimes as low as 13.2v) when at idle.
If I turn everything back on, the voltage dips even lower for a second, then stabilizes back around 13.4 - it never increases anywhere near 14.1 at idle, regardless of load.
Old 04-29-2010, 11:50 PM   #12
yaris-me
Learn to Relax
That is why there's a battery. The alternator will adjust and cover the demand, if it's not too great. If you're often faced with a drained battery, then you need to do something.
Transmission Question CMR General Yaris / Vitz Discussion 42 04-14-2010 12:38 PM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
So question here abt hatchs in general Jem_hadar General Yaris / Vitz Discussion 12 01-06-2009 03:06 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
