Old 04-28-2010, 10:39 PM   #181
swidd
Drives: Yaris HB
Are drl's fog lights or part of the main light house?
Old 04-29-2010, 12:09 AM   #182
They are the actual headlight bulbs, pulsed to be a bit less bright and hence prolong bulb life.
Old 04-29-2010, 09:24 AM   #183
fratzica
Diesel Inside
fratzica's Avatar
Drives: Yaris 1.4 D-4D
can the removed module be installed on headlights with no DRL?
fratzica is offline   Reply With Quote
Old 04-29-2010, 09:31 AM   #184
Not easily, as there are quite a few wiring differences between cars built with an without DRLs.
Old 06-28-2010, 10:21 AM   #185
Steveh27
Drives: 2010 3dr hatchback auto red
No DRL ?? Good??
I picked up my 2010 3 door HB last week, 6 months old w 4600 miles and found this wonderful site. Lots of helpful info. I've been thinking about several DIY mods: removing the DRL & maybe the back Toyota name. But , Saturday I checked and I have no DRL. DO you think the first owner did the disabling? As I don't want it anyway I'm probably not going to do anything.
The car came with most packages & options, but I was disappointed yesterday to discover it does not have adjustable intermittent wipers, only fixed one speed. That should be standard. Is it something that could be added?
Steveh27 is offline   Reply With Quote
Old 06-28-2010, 10:27 AM   #186
DRLs were eliminated on 2010's.
For the true intermittent wiper piece, check out this thread for a DIY on replacing the stalk, with a Prius one.
http://www.yarisworld.com/forums/sho...ight=diy+wiper
Old 06-28-2010, 03:47 PM   #187
Steveh27
Smile CTScott
Wow, thanks for the info. I'm happy about the no DRL. The manual says how it works 'if equipped'.
The wiper mod looks simple. But, I'm having trouble finding a low price like you got. Will call some junk yards maybe. The online dealer price was about $148.
Old 06-30-2010, 04:53 PM   #188
yaris2010RS
yaris2010RS's Avatar
not in any canadian yaris
Old 06-30-2010, 05:00 PM   #189
OK - Good to know. For US Yaris elimination of DRL is listed in the "New Car Features" for 2010. The Canadian ones still having them explains them still being documented as "if equipped" in the 2010 EWDs.
Old 07-17-2010, 03:14 AM   #190
bayou blue Yuri
Drives: 2006 3dr Yaris RS
Disconnected DRL, is there a way to make the stock fogs work now?
bayou blue Yuri is offline   Reply With Quote
Old 07-17-2010, 10:25 AM   #191
yaris2010RS
ur gonna have to put the module back in and only cut the big blue wire.
i personally opened mine up and cut a chunk out of the internal wires
Old 07-17-2010, 10:48 AM   #192
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
dont cut the wire..just pull it out just need small flat screw driver..
Old 07-19-2010, 04:44 PM   #193
yaris2010RS
u can pull it out?? lol, y was i never told this?
always trust the pull out method
Old 07-19-2010, 06:01 PM   #194
marcus
toyota
marcus's Avatar
yah you can i was about to cut it then notice the drl box just slides out and just by looking at the blue wire you can insert a small flat screw driver on the side and itll slide right off..
Old 09-16-2010, 09:26 PM   #195
Kaya B.
Drives: Yaris
The more I look at the EWD for the European version of the DRL module, the more amazed I am about how different it is than ours.
One other quick thing that you can try is unplugging the green wire in pin 8 (the green wire next to the brown wire). This wire is the input from the alternator that tells the DRL module that the engine is running. With it removed, the DRL will think that the engine is not running and therefore won't waste the power to run the DRLs.
Attachment 31197
Sorry,
Once I tried; i pinned out wrong cable :( It didn't worked.
Then I didn't have enough time to try it. New marriage, new house, moving, holidays and lots of works.
I will try in the following days and give my reply. Thanks for your helps.
Kaya B. is offline   Reply With Quote
Old 09-20-2010, 03:42 PM   #196
Kaya B.
Drives: Yaris
I finally disabled on my 2010 canadian model.
I cut the green wire coming from the alternator and another gray wire coming from the alternator. I'll take photos tomorrow about which cables i cut.
Old 09-21-2010, 04:50 PM   #197
Kaya B.
Drives: Yaris
finally,
here is the schema.
Old 10-26-2010, 06:23 PM   #198
Idahotom
Drives: 2008 5 sp. LB
I've had my Yaris only 2 weeks now, and am so happy to get the info on how to disconnect the damn DRL's! Just last evening, upon arrival home from a 25 mile freeway drive, as I pulled into my garage I realized I had been driving on the DRL's, and of course no tail lights. Hey I know it is a supposed saftey issue but in my case not so much!
My Toyota service manager I called was only good for telling me there was NO way to disable them, HA!
Idahotom is offline   Reply With Quote
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 04:12 PM
