Old 04-27-2010, 09:38 PM   #19
mshekleton
mshekleton's Avatar
Drives: 2007 Yaris HB
Why have you put on coilovers and not aligned your car?... Thats the first thing you are doing wrong. Get an alignment setup on hw you drive your car and what you do with your car. It will make it handle alot differnetly and get rid of that understear problem you are having.
I actually haven't even driven it since I put them on. I've been out of the country for work. I was thinking about setting it at -3 degrees. Not my daily driver so I don't care about tire wear.
UltraRacing everything. Megan coilovers. Kaminari body kit. AFE intake. HIDs. Halo/LED headlights. Megan exhaust. Focal F05 with 205/45/17 UHP. Super awesome tints. Carputer: OBDII realtime data display, centrafuse, 3D map navigation, radio tuner, 7" touchscreen monitor. 250W sound system.
mshekleton is offline   Reply With Quote
Old 05-09-2010, 11:27 PM   #20
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by d1nzfe View Post
anyone tried to make the underbody as smooth as possible yeah? other then front underpanel?
Old 05-09-2010, 11:54 PM   #21
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
The sedan is actually lighter than the hatch
i dont think this is true
i think the sedan has like 50-100 lbs more than the lb
Old 05-10-2010, 06:00 AM   #22
d1nzfe
Drives: 1NZ-FE
Originally Posted by Bluevitz-rs View Post
nice DIY.
Did u notice any difference on rainy days?
d1nzfe is offline   Reply With Quote
Old 05-10-2010, 10:08 AM   #23
kngrsll
Apexing Egg!!
kngrsll's Avatar
nice job... i need to do something like that...
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 05-10-2010, 08:16 PM   #24
Bluevitz-rs
nice DIY.
I couldn't tell ya. I haven't driven in the rain with these tire without it. So I have no comparison. I did however drive through a puddle deep enough to shot water over my car the other night. LOL LOL Car stayed straight as an arrow.
On a plus side. Cornering at 120+km/h feels like I'm on rails now. And I have all kinds over oversteer if I'm not on the throttle or have to lift mid corner. But that's also because I put some cut Ford Aerostar rear spring in the back. They're freaking stiff is all I can say. I would guess the rate to be north of 400lbs/in.
Old 05-12-2010, 11:50 AM   #25
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
According to Toyota, using the 2010 models as reference, the 3 door hatch weighs 2lbs less than the sedan, which weighs 7 pounds less than the 5 door hatch. All manual transmissions. In order as mentioned: 2311 2313 2320
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Observations on LB turbulence GeneW Fuel Economy Forum 18 11-28-2008 09:22 PM
yarisworld sticker installed! spkrman Photo-Video-Media Gallery 12 02-25-2007 11:50 AM
