![]() ![]() ![]() Drives: 2008 5-door Yaris Hatchback Join Date: Oct 2008
Side turn signals. Has anyone done this...???
Has anyone wired the side turn signals (the ones just behind the front wheels) to the parking lights lead, so that they are always on?
I would still want them to function as blinkers when I want to turn or with hazards, but remain on full time like the parking lights when not blinking. Smart Cars do this, and I think so do BMW and Porsche. I think it looks cool, and give better visibility to the vehicle for safety as well. Any ideas??? P.S: Not my car... stock photo. |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
why? they're blinkers, not side-markers. both the front and rear housings have sidemarkers on there. so why would you want to take away a blinker and put a marker?
if you wanted to, you can put a dual filimement bulb in there and make it both marker and blinker. like a white led for marker and yellow for blinker. that would work well i think what i'm wondering is why in the world the bulb housing sticks out almost as far as the side-mirrors....why hasnt someone come out with a flush-mount or near flush led kit for these? it looks like an insect eye....on the side of an insect eye. |
Not quite a noob
There's no way to mount them flush without having the LED inside the car body, which would still require some sort of clip to protrude a bit so that there's something for the entire thing to clip to the body with
i understand that, look at the new bmw. they use led's, and they're not even 1/4" above the body panel. the yaris is like a bug eye out there in left field....looks goofy, out of place
#5 | |
Mr. 155 and climbing
If you search you will find LED housings that are just about flush that you can purchase overseas. I have seen at least a half dozen different styles of flush mount LED Side Marker housings.
I've done this on my sedan. With the aid of CTScott, this was cake.
One wire from the marker was designated to ground, the other split into two other wires. One went to the parking lamp wire, the other to the one that controls the turn signal. I can't remember the exact wires, I'd have to look. You're gonna need diodes (pointing toward the marker) so that the two wires don't feed each other. Also, a resistor is needed in the wire that connects to the parking lamps, otherwise when the blinkers are triggered there will be no effect (while the parking lamps are on). I'm surprised so few people have done this, as the illuminated markers, fogs, and HIDs look sooooo slick at night
#7 | |
I wouldn't like a dual-purpose light; blinker and side marker when not blinking. I don't want to replace anything, just do some creative wiring.
#8 | |
#9 | |
If I had to take a stab at it, I'd say you just need to find the negative wire in the harness connecting to the back of the marker, then do what's in the diagram. I tapped into the appropriate wires right behind the headlights. Again, I'll look and get back to you. As for the resistors and diodes, the cheapest diodes will do. Resistors are iffy, as I never actually did this part (but know it's necessary). Play around with different values until you find one that is bright enough to satisfy you. |
Thank you.
Did you confirm this works? |
I wouldn't suggest doing this unless you change the side markers to LEDs.
With the stock incandescent bulbs you would need to use a 30 ohm, 1 watt resistor, and the resistor would get very warm when the lights are on. |
やりすぎだ~
Anyone selling their side markers? I wanna do this, but not on the ones that are on the car now.
#13 | |
black shark
Drives: black toyota yaris t3 sprit Join Date: May 2010
www.justbabynappies.co.za |
#14 | |
Why would they get hot? Its the same bulb as the parking lights. Again, just assuming.
#16 | |
The resistors would get hot because of the current required to drive the 5W bulbs. The aftermarket LED side markers draw less than 100mW (1/50 of what the bulbs draw), so dimming them doesn't require sinking the power that dimming the bulbs requires. |
![]() Drives: Toyota Belta Join Date: Nov 2012
any safe way to do this mod with stock incandescent bulbs?..
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
there is a different way of wiring it with incandescent (stock) bulbs. the difference is they will alternate with the turn signals (at night) when the park lights are on. In the morning, they function normally.
wire the positive wire of the park light to the negative end of this side blinker. that's it. HTH. That's how i used to do it on Civics during the early 2000s. |
| Additional turn signals | yarisugi | Photo-Video-Media Gallery | 24 | 02-06-2013 08:08 AM |
| Are rear red turn signals planned for Yaris as well ? | 77W | General Yaris / Vitz Discussion | 38 | 02-22-2010 06:41 PM |
| Audible turn signals | tforkner | DIY / Maintenance / Service | 9 | 08-08-2009 09:50 AM |
| turn signals blinking fast | manborn | DIY / Maintenance / Service | 15 | 09-15-2007 01:52 AM |
| Side Turn Signal Lights | bigsky2 | Cosmetic Modifications (Exterior/Interior) | 15 | 08-24-2006 06:06 PM |
