#19 |
just checked the 2010 and it's the orange / brown color . There's about 7,000 miles on it . This seems normal . Hopefully , not all our YARII have coolant leaks . Very doubtful .
#20 |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Thanks, Man. After adding a pint of distilled HOH over a week when cold in the morning, the level has stabilized the past 3 days - not loosing any. Hope it was just the dealer checking the coolant when HOT and spilling some out or making a air bubble that I worked out ? ;) All was well before the 30K Toyota dealer service.
#21 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
Dosen't anybody use Prestone or Peak brands anymore? I quess its a Green color. I am colorblind so cant tell Green and Brown
#22 |
@silkysmooth;
Are'nt you the same member who stated the OEM Thai filters would damage the cars?? I've been using them since day one. 25k miles later, and no probs.
#23 |
if you get the nerve you could look at some used YARIS or even a new YARIS to check under the radiator cap for the orange - brown coolant . That's what we did . Sure it peed off a few salesman that went and got the key so I could pop the hood to a look around as if we were possibly interested in purchasing them . All for the sake of our YARII . Though it is a bit embarassing
. Wonder if the coolant in the 2004 > 2006 XBs are of the same color . Guess I'll have to check out a few used XBs now .
#24 |
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
I checked my coolant from the readiator and looked brown and rusty too, I took a white napkin and let it absorb some of the coolant and the luquid looks pink as in the reservoir, so maybe is the black background that make it look rusty.
#25 |
And this has what to do with coolant? I was having problems after an oil change getting oil pressure with the thai filters I bought - On two separate cars in multiple instances. Thats more than coincidence or bad luck. Just relating my experience - doesnt mean it applies to everyone/ situation. I guess I could shut up and say nothing. That may comfort the paranoid types or the Iconoclast that arent comfortable in their own skin ;)
#26 |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
I think Lucas13 is on the right track. I checked the coolant in my 09 and in the overflow tank it was bright neon pink and under the rad cap it was rusty brownish orange. I too think its the darker background changing the color. I didn't think to blotter test it like he did though.
R2 |
| Coolant Service | N9QGS | DIY / Maintenance / Service | 31 | 11-27-2012 06:55 AM |
| when car idle coolant goes to 200+ degrees | N9QGS | DIY / Maintenance / Service | 7 | 05-09-2010 11:14 PM |
| Check your coolant bottle | UTVitz | DIY / Maintenance / Service | 13 | 12-16-2009 09:13 PM |
| Coolant Smell after sitting in hot sun? | Snappy | General Yaris / Vitz Discussion | 3 | 05-31-2009 12:18 AM |
| 30K throttle service | jaggurnaut | DIY / Maintenance / Service | 39 | 09-11-2007 08:34 PM |
