Old 05-26-2010, 11:24 PM   #1
jessicammhm
Drives: 2007 Toyota Yaris 4dr 5speed
Increasing Horsepower: What Should I Add To My Yaris?
I have an 07 Yaris 5speed and was wondering what I could add to it to increase the HP. I've heard iridium spark plugs and better intakes and stuff but has anyone made any mods on theirs to increase HP? If you know of anything that has helped you let me know. Thanks!
jessicammhm is offline   Reply With Quote
Old 05-26-2010, 11:32 PM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
1zz throttle body if you can make it work
NST underdrive crank pulley.
intake
header
exhaust
Old 05-27-2010, 10:14 AM   #3
cdydjded
Drives: Yaris LB Turbo
I concur with the above statement.....
Old 05-27-2010, 10:20 AM   #4
+1
And whether or not I get flamed for saying it -- use the search feature first, there is a wealth of knowledge already on here that will answer your question completely, starting with the "Performance Primer".
Old 05-27-2010, 11:36 AM   #5
hatchbackkid82
Drives: .
Mid pipe, + the full pulley kit, light weight flywheel.
intake
header
exhaust
Old 05-27-2010, 12:01 PM   #6
Astroman
Modded Moderator
Astroman's Avatar
Weight reduction helps too.
Old 05-27-2010, 02:28 PM   #7
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
i think the spark plugs should be addressed. arent the iridium plugs marketing trash? or is it different for this car?
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
Old 05-27-2010, 03:30 PM   #8
I never had a problem with the stock spark plugs, street and track. Someone would have to dyno test one brand/type against another to prove to me that there's a difference in power output.
Old 05-27-2010, 03:33 PM   #9
intake, dc header, an exhaust thats more than just an axleback (ie from the resonator back)
with just an intake and res-back exhaust i pulled 106whp/107wtq on a dyno
nst lightweight or underdrive crank pullies are nice too
Old 05-27-2010, 09:03 PM   #10
CarBob08
Drives: '08 3-Door
Here are the things that made my car "feel" a whole lot better.
1. NST pulleys (very nice throttle response difference)
2. DCSport header (helped smooth out the power across the band and much nicer at the high end)
3. Modified air-box (most people do cold air intakes, I like to cut stuff, so I modded the box and used a K&N stock sized filter. This gave me +2mpg and a bit more low end power)
4. Believe it or not, setting up a second ground from the battery to the ECU seemed to really smooth things out all through the mid-high rpm range.
Have fun with your upgrades!!
CarBob08 is offline   Reply With Quote
Old 05-27-2010, 11:05 PM   #11
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
I agree with this 100%.
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Old 05-28-2010, 12:14 AM   #12
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
The Yaris comes with Iridiums stock...
Old 05-28-2010, 11:00 AM   #13
ddongbap
You are all wrong. Stickers. That is all.
Old 05-28-2010, 12:59 PM   #14
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
, and a huge wing.
Stove is offline   Reply With Quote
Old 05-28-2010, 01:30 PM   #15
PETERPOOP
PETERPOOP's Avatar
spinners?
Old 05-28-2010, 01:32 PM   #16
wing. check.
stickers. check.
ooh, spinners. I don't have those yet, thanks
Old 05-28-2010, 02:27 PM   #17
cdydjded
Fuzzy dice hanging from the rear view mirror & a flux capacitor
Old 05-28-2010, 02:29 PM   #18
Astroman
Modded Moderator
Astroman's Avatar
har har.
Paint stuff yellow. +10hp for yellow stickers, lol
Turbo, supercharger, nitrous, lightweight wheels/tires.
2007, 5speed manual, horsepower, increase, sparkplugs
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
Help sign this petition! Add the Yaris and other small cars to Forza 2 eTiMaGo Off-topic / Other Cars / Everything else Discussions 24 08-10-2007 12:57 PM
