Old 06-08-2010, 10:05 AM   #19
fett22
Drives: 2004 yaris t-sport turbo
need these
fett22 is offline   Reply With Quote
Old 06-08-2010, 11:24 AM   #20
fett22
Still having the air leak after replacing the o ring, defenety the BOV is ruined,but sounds so good . I am concerned about air/ fuel misture with these leak , is not some much air what i am lossing, but maybe after some miles i will have again the CEL, TRC AND VSC ligths have to wait to see whats up with that.
Old 06-08-2010, 06:17 PM   #21
fett22
lights are on again.
Old 06-08-2010, 09:24 PM   #22
Do you have a scantool to read the DTC that causing the CEL to light?
Did you swap your ECM for the one you received with the turbo? If so, did it come off of a Vitz that had TRAC and VSC?
Old 06-08-2010, 09:32 PM   #23
fett22
tomorrow i am gonna scan the car, i used the car almost about 2 weeks with the turbo computer on no cel, try track control and worked fine, as soon as i installed the BOV, have the cel, and vsc trc ligths on,so not sure whats the issue.
will post info about the scantool.
Old 06-08-2010, 10:02 PM   #24
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Did you pressure test it or just slap everything together? If not, build a pressure tester, hook up some air w/ a regulator! and see how it goes, you probably have more leaks than you think.
In reality, we all like to believe its easy to slap something together and just have it work, but theres always going to be small hickups.
Old 06-08-2010, 11:23 PM   #25
Yaris0609
Drives: 09 Yaris 3 DR HB
can you tell us where you have the vac line for the blow off valve hooked up? looks to me like thats the problem, I just cant tell where the line t's to. I see it going from the throttle body to the "t", then from there i can't tell. You should be pulling vac for the BOV after the throttle plate, like from a nipple in the intake manifold.
Yaris0609 is offline   Reply With Quote
Old 06-09-2010, 12:28 AM   #26
Nexus1155
Drives: Audi
Now looking at what he said that looks very awkwardly setup.
I can somewhat see it going T'd from throttle body nipple, to the bov, then T'd back into a checkvalve into the MAF sensor/airbox?
Old 06-09-2010, 01:01 AM   #27
Yaris0609
in the parts diagram, there is no picture of a BPV. Maybe Toyota wanted it that way, small motor, small turbo, no reason for an anti lag valve(BPV), that turbo probably makes max boost at no rpm. If you want to run that BOV, you might need to plumb it differently....
Old 06-09-2010, 10:28 AM   #28
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Looks like it's routed TB-"T"-BOV/EVAP purge valve.
You might want to add a One Way vacuum valve just before the EVAP valve. You might be leaking boost through it.
Old 06-09-2010, 11:07 AM   #29
Nexus1155
Drives: Audi
Recirculate it..... BOV is cool for noisez i won't lie
Old 06-09-2010, 02:24 PM   #30
fett22
i take the vacum line from the same as the picture, i have a frend with exactly same car as mine and he use the vac line from same place that i take it,and that worked great for him, definitely theres and air leak couse of valve spring isnt closing completely , so after i change the valve were gonna see if thats the problem, thanks for all the info.
Old 06-09-2010, 06:11 PM   #31
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Running a bov that vents to the atmosphere is not recommended on cars with an air flow meter (such as your car) as it will run real rich on gear changes. If the outlet from the bov was plumbed back in to the piping after the air flow meter but before the turbo, you will get correct air flow readings, correct fuel mixtures and no cel's.
Because the bov is open at idle, it is drawing in un-metered and unfiltered air and that is what is causing the cel's.
rob323 is offline   Reply With Quote
Old 06-09-2010, 07:58 PM   #32
fett22
i think your absolutely rigth,tomorrow will take out the BOV, and weld the intercooling pipping.
theres no fun in having a cool sound in you car BOV, is thats gonna damage it.
Old 07-13-2010, 03:39 AM   #33
fett22
here;s the update i went to track and i am doing 15.5 s , and 15.9 with wet track, i have stock mufler with Cat, i will install a magnaflow and take out the cat, also need to replace the BOV, maybe on wekend.
so these is how it went, great response at beggining , turbo start boosting at 2.5 rpm up to 4.5 like a charm,but at higher rpm, in third and fourth gear , from 4.5 to 6 rpm engine acceleration decrease a lot. I need a few advices of what to do.
Also stock clucth is not responding so well, i felt a lot of power its been loosing from that ?
Before turbo i was doing 17.4 , so i gain almost 2 seconds, i have a friend that with same car turbo , its doing 14.8 just with turbo, no exhaust no aftermarket clucth ,
so what can be wrong with my car?.
i am boosting 0.5 bar, thats what trd computer its setup.
i am plannig to take it to 14s , so besides clucth, muffler ,crank pulley, what are other mods i could do?
Thanks for all.
Rodrigo.
Old 07-13-2010, 11:29 AM   #34
Before you consider more mods, make the car as fast as possible like it is.
What gauges are you watching while you race?
Old 07-13-2010, 04:42 PM   #35
rob323
Pressurise the intake to check for air leaks and a leaking bov. They will cause a loss of power at the top end.
Old 07-13-2010, 09:55 PM   #36
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Thanks for all.
Rodrigo.
In all respect, maybe he's a better driver?
Tags
trd turbo plan
Trd sport M badge (carbon RARE), td05 Mitubishi turbo flatline16 Items for Sale by private party 14 09-28-2010 07:20 PM
TRD Turbo Vitz 田中秀樹 Forced Induction Forum 26 09-26-2007 03:07 PM
Yaris Sport Turbo BY TRD Fer.pa Central and South America 18 07-31-2007 12:05 AM
TRD Turbo ECHo Hatch - Yaris TS CASTREX General Yaris / Vitz Discussion 12 04-03-2007 11:04 AM
NCP 91 RS 1500 TRD Turbo ????? ramishrrr General Yaris / Vitz Discussion 3 01-15-2007 04:51 PM
