Old 06-10-2010, 08:33 AM   #19
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
Originally Posted by RedVitz View Post
Yes, i mean the brake shudder. I know 6 TS drivers they have the same problems. In my car it was from the beginning to... that's why i ordered the D2 Brake.
ahh ok i see , so it seems to be a widely noted problem then , thanks for the information buddy .
i wonder if the celica aftermarket discs will work , as the TS has 275mm discs , and so does the stock celica with the 2zzge motor in ?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 06-10-2010, 08:34 AM   #20
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
do you know of any other problems that the TS has ? or what to look out for ?
JDMtuner
www.jdmtuner.co.za
Old 06-10-2010, 12:29 PM   #21
RedVitz
Toyo Lover
RedVitz's Avatar
Drives: Yaris TS XP9 VFL
Send a message via ICQ to RedVitz
I don't know whether this fits, sry. But I can find this out. Do you want a complete new braking system or only other discs?
No, there aren't big problems. You should look only now and again after the oil. Because after a fast ride, the TS needs oil.
RedVitz is offline   Reply With Quote
Old 06-11-2010, 01:14 AM   #22
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
No, there aren't no big problems. You should look only now and again after the oil. Because after a fast ride, the TS needs oil.
yes , at the moment im looking to change just the discs for now to better ones.
ah ok thats good news , i keep a eye on the oil level , mine has never dropped since i have had it , never needed to fillup , but , will keep a eye on that , thanks buddy.
JDMtuner
www.jdmtuner.co.za
Old 06-11-2010, 02:31 AM   #23
RedVitz
Toyo Lover
RedVitz's Avatar
Yes, the TS needs only oil after a fast ride on the highway. We haven't in Germany no speed limit, that's why you go faster and faster till the limiter and then the oil temperature is going to 130-137°C
But back to topic, i try to find out wether the celica discs work
No Limitation As A Limitation!
www.ajr-performance.com -> Custom High Performance Parts
Old 06-11-2010, 04:13 AM   #24
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
haha , i like the no speed limit rule , i have only been to 200 kph twice in my car , as here there is alot of speed traps. but i will check the oil again to see my level.
ok great , thank you , let me know what you find out , would be cool if the celica aftermarket discs could work on the TS.
JDMtuner
www.jdmtuner.co.za
Old 06-11-2010, 04:43 AM   #25
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
hi buddy
if the oil is going to give problems then change it with a high performance oil, also u need to keep a eye on brake fuild, if the disc are getting warpped that means the temp is high, brake fuild boils at 200 and something degrees, find out what dot is in your car and change to a higher one, that should help also
www.justbabynappies.co.za
nazier is offline   Reply With Quote
OEM Yaris brake pad kit PICS auxmike DIY / Maintenance / Service 17 11-24-2009 11:42 AM
