Drives: Yaris CDX 1999 Join Date: May 2010
Yaris CDX 1999 P0171 error code
Hi to all at Yaris World.
My Yaris CDX 1999 model had the CEL come on twice in a week. The code reader states it is P0171 - Adaptive fuel too lean -Bank 1. About 2 weeks ago I noticed that the idle speed was about 550 rpm so I cleaned the Maf sensor, trottle body. I did not remove the Idle Control Valve since I did not have a gasket. I also added a fuel additive (Lucas) to clean the fuel system. The idle speed still remained the same so I adjusted the Idle Screw. So the above are not the cause. Now I checked the vacuum pipes from the canister. All seem OK. My daughter is using this car to learn to drive and since she is new at driving she frequently knockes the vehicle when releasing the clutch. I have noticed that the CEL is coming on a day after she goes driving. Could this have to do with the CEL coming on. Here under are the Code reader/Scanner readings. All technical advice would be greatly appreciated. MIL Status MIL Status On Misfire Monitor OK Fuel System Mon Ok Comp. Component OK Catalyst Mon OK Htd Catalyst n/a Evap System Mon n/a Sec Air System n/a O2 Sens Mon OK O2 Sen Htr OK Efr System n/a Trouble Codes Codes Totals 02 Fault Codes 01 Pend Codes 01 P0171 - 01/02 - Generic System Too Lean (Bk 1) P0171 - 02/02 - Generic System Too Lean (Bk 1) Freeze Frame Trouble code P0171 Fuel Sys 1 n/a Fuel Sys 2 n/a Calc Load (%) 35.6 Coolant (°F) 183 ST FTRM1 (%) 0.7 LT FTRM1 (%) 29.6 Engine (RPM) 2270 Veh speed (MPH) 40 IAT (°F) 102 Live Data (at Idle) Fuel Sys 1 cl, using HO2S Fuel Sys 2 cl. Using HO2S Coolant (°F) 187 ST FTRM1 (%) -1.5 to -4.6 LT FTRM1 (%) 3.8 Engine (Rpm) 652 Veh Speed (Mph) 0 Ign adv (deg) 8.0 to 9.5 IAT (°F) 129 MAF (lb/min) 0.134 ABSLT TPS (%) 10.9 O2S11 (V) (%) 0.085 to 0.705 -2.3 to -3.9 O2S12 (V) (%) 0.72 to 0.75 n/a |
![]() Drives: Yaris 3 dr hatch back Join Date: Jan 2010
what kind of code scanner are you using ?
have you ruled out bad gas too much alcohol or water in the gas or clogged fuel injectors ?
Just a WAG (Wild Ass Guess) method deduction. |
| I think I was being made fun of for driving a yaris (or my yaris) last night.....hehe | PETERPOOP | Off-topic / Other Cars / Everything else Discussions | 21 | 05-16-2010 03:19 PM |
| is the yaris for me? | sauruman | New YARIS Purchase Forum | 14 | 02-27-2006 08:27 PM |
