![]() ![]() ![]() Drives: peArL yAvItZ!! Join Date: Jul 2009
All Thai Yaris with NST pulley, pls read...
Hi to all, can anyone Thai made Yaris mount on the water pump & alternator pulley without any problem? Are they the SAME OEM side pulley? All Thai Yaris with this mod, PLEASE advise & confirm...
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres |
One of the three pulleys requires a shim, I believe it is the water pump.
[edit] it's the alternator pulley, see below
Micro Image forums, online store and shop are now closed. It was a great eight year run, but it was time to focus on other things. I'm still selling parts on eBay under micro*image seller ID and customers can still make requests for anything specific. Last edited by cali yaris; 06-29-2010 at 10:46 PM. |
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
A shim on water pump? Do we need that on usmd yaris
it is the alternator pulley, the design is a little bit different, you can install it, but you need to put in a spacer to align it properly. you should contact the member MANSETH here, he has done it.
nothing needed on USDM cars.
Thanks to all who reply.
Bro eTiMaGo, i remember reading up your old post that the alternator pulley doesn't fit into our thai yaris. But do you still mount it with additional spacer as mentioned? thank you.
![]() Drives: Toyota Yaris 1.5 M/T '06 Join Date: Oct 2009
hello, i just wanna share my experience..
i bought my pulley from a supporting vendor here, MICRO IMAGE, after i scour the forums i decided to put up only the 2, underdriven crank + water pump. so alternator pulley not changed. works fine for me, and i believe a change in the alternator pulley doesnt generate much/any power one can feel... if not for the viewing pleasure... mine's a thai built yaris in indonesia. hope it helps. |
Thanks Schizoprenia for sharing.
I pm MANSETH regarding this. He managed to put on all 3 pulleys at one go. Only the alternator pulley require some shim/spacer to alight the belt. Since you have the alternator pulley, why not try it with some shim/spacer?
![]() Drives: Yaris Sedan Join Date: Jun 2010
I have thai built Vios, I just bought NST underdrive set (Crank, WP, Alt) from MI last week, and still in shipping ..
what kind of shim/spacer should i use, so all pulleys can be installed? maybe anyone have pictures? Thanks,
|Blitz S/C|aFe Intake|NST SSK|NST Busing kit|Ralco Short Shifter|Dastek Unichip type Q|Dastek Throttle Control|1ZZ Injectors|1ZZ TB|Custom Header|Custom Exhaust|Head Porting|Momo Drifting Steering wheel|Momo shiftknob|Denso Irridium Sparks|Buddy Club P1 Racing Wheels|195/50/R15|Tanabe NF Coilover|Goodrich SS brake lines|Ultra Racing Front Strutbar|NRG Grounding kit|Custom Grill|Custom Eyelid|Rear Sway bar| |
KAVINT
Drives: KAVINT Join Date: Dec 2008
Guys,
Sorry, for late pictures. I spend sometime to find the NST because I already put on the supercharger. This is Metal lathe. The reason I use metal because I experienced aluminum slip. ![]() For thickness, I suggest you guys to measure the differences of the stock one and NST in order to get the straight between alternator and water pump. ![]() By kavintyaris at 2010-07-06 |
![]() Drives: 2007 Vios Join Date: Jul 2010
Shouldn't be a problem fir vios in singapore den cos it's thailand made.
Shall order thru MI soon
| FS: NST 10% Underdrive Crank Pulley | hatchbackkid82 | Items for Sale by private party | 11 | 02-26-2010 08:22 AM |
| Hmmmm noticed substantial mpg increase with nst pulley... | YarisSedan | Performance Modifications | 11 | 04-16-2009 04:42 PM |
