Old 01-15-2007, 11:08 PM   #1
tiksman
tiksman's Avatar
Drives: 07 Red Hatch
DIY Ebay fog lights
I purchased these lights from user jimcat here on Yarisworld. They are a great little aftermarket kit. I was very impressed with the fitment.
There has been a few tutorials but not to easy to follow. The bulbs that came with them are the stock dim look and I installed some hyperwhites.
Box they came in
Factory style harness
harness out of box
Factory style fog light switch, Factory style plug.
Rear of light shot
fog light out of box shot
Squeeze cilps to remove plastic cover from bumper
Factory covers removed
installing in lamp in Bumper only 1 screw is used per side
Inside bumper shot
Fogs installed
pull up at ebrake handle to remove switch bank
Switch in place of dummy panel
Switch installed
Switch with fogs on. there is no light on the switch when fogs are off not even night illumination
Without flash
With camera flash
Wire Diagram
http://www.dropshots.com/zoomin.php?...0070106&cimg=3
Bigger photo for diagram link
The only problems I had is there is no instructions and the harness is factory style and all the plugs look factory but there is no place to hook them up. There are 2 wires a large one going to a fuse and to the relay and a small red wire that is 12 volt feed to power the relay. I used the 12 volt outlet (grey wire) for the red wire and a hard line from the battery to the white wire. The way is works is key on and fog switch on you have fogs with or without headlights this is the way I wanted it. I can even have fogs with brights on.
I think the kit is a good quality kit. I got mine on the cheap (cheaper than ebay)
Jimcat is in Hong Kong and he gives super fast shipping He got it to me in Georgia is about 4 days
UPDATE!!!! READ Carefully
1) On the front harness where can I find the best grounding bolt? I think there is one close to the pass headlamp on the frame rail.
2) What switched 12V source do I hook the red wire up to??
A --Use the grey wire from the 12 volt outlet. It has a plug on it. It is a little hard to reach arround and get to but not to bad. You will have to cut the plug off on the fog harness there is no plug that connecter they have fits into our cars.
3) The wire that the brown thing is connected to, I am assuming that it goes to the battery correct and if so is it + or -?.
A--Large white wire with brown plug, cut it off and put on a connecter to hoof it strait to the battery.
BROWN plug is the same no place to plug it in on a US Yaris.
4) And Lastly where exatly did you mount the relay???
A---I mounted it with a few zip ties behind the glove box.
Also take the wires out of the ac drain tube groment. You will need to extend the wires some into the engine bay. Mount the fog harness from pass to driver (driver being the very end of the harness).
I drilled a hole and picked up a groment off a old Dodge neon radiator mount. Worked great and I dont have to hunt to make it into the engine bay for future wires.
tiksman is offline   Reply With Quote
Old 01-15-2007, 11:25 PM   #2
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
Thank you so much..I'm, getting mine this wednesday..!
-- Blen
Old 01-16-2007, 08:41 AM   #3
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
very nice
will work for parts
vodkalush is offline   Reply With Quote
Old 01-16-2007, 09:35 AM   #4
spkrman
Drives: 1
jimcat?
looks sweet!
Old 01-16-2007, 10:36 AM   #5
tiksman
tiksman's Avatar
Originally Posted by spkrman View Post
jimcat?
looks sweet!
Yes you know the one with the light electric green Yarii
http://www.yarisworld.com/forums/member.php?u=1178
Old 01-16-2007, 10:58 AM   #6
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Send a message via MSN to jimcat
Wonderful
jimcat is offline   Reply With Quote
Old 01-16-2007, 12:01 PM   #7
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
That's a nice looking kit. I like the adjuster facing downward - not to the back like my eBay version.
What do you mean by 'fried egg' look? They look like standard clear H11 bulbs to me. Most people say fried eggs about yellow/amber lights (which would be nice for a fog). That coating on the tip of the bulb is supposed to be there.
Old 01-16-2007, 01:37 PM   #8
tiksman
tiksman's Avatar
I thought the kit was real nice too. It fit very well. I may be mis quoting the fried egg look but to me with my stock headlamps (b4 the hidled units and brighter bulbs) they looked like yellow dim fried eggs. the fogs are the same they need some hi intensity white h11 lamps.
Old 01-16-2007, 03:15 PM   #9
rwseattle
Rwseattle
rwseattle's Avatar
Drives: 2007 Toyota Yaris (BASE)
Fog lights
I purchased these too, great set. Easy to install, 2 hours.
rwseattle is offline   Reply With Quote
Old 01-21-2007, 04:48 PM   #10
Chiefy707
XBox360 Fanboy
Chiefy707's Avatar
Drives: 07 Bayou Blue LB
Send a message via AIM to Chiefy707
Cool isht! I just installed what looks to be basically the same set on my Yaris last night. Where did you route your harness through to get inside the car? I took mine through the parking brake cable hole (had to cut a small groove in the grommet so it still seals even with the wire fed through. Cut off about 18" of the plastic insulator so it could fit but put it back on when the wire was fed through.) I couldn't figure out what the brown connector and white connector plugged into so I just spliced them into the power wire for the 12v outlet. My fogs came with hyperwhite bulbs though. Pix soon.
Now as for those CQ Lighting HID's and JDM Vitz tailights...
Chiefy707 is offline   Reply With Quote
Old 01-21-2007, 06:17 PM   #11
tiksman
tiksman's Avatar
Check the brown Plug (larger wire be sure to get power dirrect from the battery or you may overload the wires and a start a fire. the larger is 12v constant dirrect from battery and the smaller wire is 12 volt swiched (got that from the 12v outlet grey wire). I did not want to cut any boots or wires so I drilled a hole in the firewall and I used a rubber washer I had from one of my Dodge neon projects ( it was off the upper radiator support). It fit perfectly and now I do not have to wory about installing new stuff under the hood and into the interior.
Old 01-22-2007, 07:24 AM   #12
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
I got some ordered from jim cat .How do you get to the power port wires been looking around to see how to take it apart even in the yaris repair manual thanks for any help
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 01-22-2007, 10:24 AM   #13
ASHRAF
Scubie Du
Drives: '10 SWP STi/'09 Escalade
Send a message via AIM to ASHRAF Send a message via MSN to ASHRAF Send a message via Yahoo to ASHRAF
thanx for the useful topic
if it was one month before, I might saved 200 or so on my installation
I had mine installed last month
I've just noticed something strange
water, or water vapour (not really sure) is getting into the fogs
anyway ton clean it up and avoid that in the future
-AJ
'05 Black Toyota Avalon Limited - Saudi Arabia
'06 Black Sand Pearl Toyota Yaris YR - Australia
'08 Fiji Blue Pearl Honda Civic Mugen Si - US
'08 Lightning Red Subaru Impreza WRX STi - US
'09 Diamond White Pearl Cadillac Escalade - US (current)
'10 Satin White Pearl Subaru Impreza WRX STi - US (current)
'11 Yaris?
ASHRAF is offline   Reply With Quote
Old 01-22-2007, 11:45 PM   #14
tiksman
tiksman's Avatar
Take out the console. 1 10 mm bolt inder the rear cup holder. Then reach under and unplug the power port.
Also I have had no water issues (been raining here like crazy). But with some aftermarket lens housingd it is a good idea to run a bead of silicone along the edge of the lens and housing. My old Dodge Neon APC tails leaked like crazy inside had to seal them up.
My fogs looked well made and well built and I am picky. I did not buy on ebay because thay wanted too damm much.
Old 01-25-2007, 03:51 PM   #15
Yaris TTE JWRC
Drives: 07 5spd red Yaris HB 1.5L 16V
I got mine installed too, i love them.
Yaris TTE JWRC is offline   Reply With Quote
Old 01-25-2007, 04:00 PM   #16
Violin
Violin's Avatar
Ooohhh....
Yellowwwww....
Nice.
Old 01-25-2007, 04:41 PM   #17
MrMondayNite
Drives: 07 Yaris LB
Just received mine Yesterday, will install when it warms up a little. Thanks Jimcat.
07 Yaris Liftback (Commuter Car)
PWR Cold Weather Convience PKG'S Keyless Entry Rear Spolier Rear Bumper Protector Exhaust Tip Mud Guards OBX Sport Pedals Factory Alloys JDM Leather Shift Knob JDM Door Edge Guards
06 Civic Ex w/Navi (Other Car)
04 BMW 330 XI (Traded in)
03 VW Jetta GLX VR6 (gave to Dad)
01 Civic EX (gave to Mom)
MrMondayNite is offline   Reply With Quote
Old 01-25-2007, 04:45 PM   #18
vodkalush
I drive a yarrrris
vodkalush's Avatar
yah the day i got mine it started snowing... sucks to not have garage to work in :-/
will work for parts
Ebay OEM style fog lights installed fantabulousbaby Cosmetic Modifications (Exterior/Interior) 29 04-28-2009 11:14 AM
EBAY OEM BUMPER FOG LIGHTS Wayside General Yaris / Vitz Discussion 41 01-09-2007 01:52 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 02:13 PM
"OEM" fog lights from ebay drell42 Cosmetic Modifications (Exterior/Interior) 5 07-28-2006 10:21 AM
Liftback Fog Lights on eBay Chris07LB General Yaris / Vitz Discussion 8 07-24-2006 08:06 AM
