![]() ![]() Drives: toyota yaris hb Join Date: Apr 2010
i have problem with the fan does not turn when the car is on and the engine temperature reaches its unique hot and the fan is turned on with the air conditioning on. guys i hope can help me thanks
Fan comes on at about 202F.
Without a Scanguage, you would never be able to tell if something's wrong with the fan circuit. What did you use to determine there's a problem? ![]()
Never take eyes off opponent - Bruce Lee |
I added a water temperature clock and have seen q reaches 210 degrees and the fan does not run and that it happened from a few days
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
Check fan relay situated into the engine bay. It could be just as simple as a loose contact
pardon me for asking but where exactly is located the relay that saw many and not all is well which saw one that said no.2 and cooling fan which is not
#6 | |
Fan No 2..jpg |
| Yaris Central Locking Problem | pbasuita | UK | 0 | 07-10-2010 03:46 AM |
| interior lighting problem tied with headlights | 40oz | DIY / Maintenance / Service | 7 | 03-28-2010 07:52 PM |
| Launching @ 4Krpm problem .... need tips | Parmas | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 12-30-2009 08:11 PM |
| How can I get in touch with Toyota Regional Offices in Houston? | woof | DIY / Maintenance / Service | 11 | 11-28-2009 09:29 PM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
