Old 07-19-2010, 07:52 PM   #109
roodhouse
Drives: 2010 3-door blazing blue
Has anyone put a GPS with a 5 inch screen in the drivers glove box and can you close the lid with it still mounted.
roodhouse is offline   Reply With Quote
Old 05-01-2011, 11:15 AM   #110
PYM
Drives: 2007 Yaris HB
I have my GPS and Ultra guage mounted in the glove box. A few judicious holes in the box allows the UG plug to remain hidden and a similar hole (cut with a Dremel) creates a tight enough fit for the GPS mounting bracket to slide in, hold the GPS at the proper angle and still allow the glove box to close (it is close). The GPS mount hole was cut just into the curved part of the "lip" of the glove box. There is "stuff" under the glove box but it was easy to avoid the important things. My GPS is a Garmin 855 with voice command ($119 ebay) , the voice command works very well and in turn you do not have to reach through or around the wheel to enter addresses etc.
The set up works well, keeps the GPS hidden when not is use, just open the glove box when driving, does not interfere with airbags or obstruct the view in any way.
PYM is offline   Reply With Quote
Old 05-01-2011, 11:33 PM   #111
Hershey
Very clever .
Old 05-01-2011, 11:45 PM   #112
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I just added some LED's to mine...trying to find something(besides the chips) in those compartments at night on the road was a PITA. I'm pleased with the results, they are very bright.
-Type 07 FFL-
My odometer 03/11
Old 05-02-2011, 12:20 AM   #113
piranha0522
Drives: '06 Yaris
I stash my weed in mine.
I mean.... my bible.
piranha0522 is offline   Reply With Quote
Old 05-02-2011, 12:22 AM   #114
mazilla
advocatus diaboli
mazilla's Avatar
Man, you carry a big bible...mine fits in the little drop down compartment to the left of the steering wheel.
-Type 07 FFL-
My odometer 03/11
Old 05-02-2011, 12:11 PM   #115
Idahotom
Drives: 2008 5 sp. LB
There's a glovebox behind the steering wheel!??
I didn't notice it until halfway back from Michigan, where I bought it. I am still in the habit though of using the two on the passenger side, too many years of having rigs with that setup! I think I have some spare change and a few bills there, there are so many other spaces I forget, and don't really need, that one, I like having it however.
Idahotom is offline   Reply With Quote
Old 05-02-2011, 04:43 PM   #116
swidd
Drives: Yaris HB
lol,. did you find the one down by your left knee?
swidd is offline   Reply With Quote
Old 05-06-2011, 06:04 PM   #117
lcastrob
Drives: hb
i keep my sunglasses and Badge ID from work
lcastrob is offline   Reply With Quote
Old 05-06-2011, 10:27 PM   #118
Idahotom
Right now I have my ScanGauge AND my Sirius dock velcro to the dash, thanks to this site they will both be going in the upper compartment. I can't believe I didn't think of that myself!
Old 05-15-2011, 08:24 AM   #119
whiteyaris
Drives: white yaris
microfiber, glasses, school gate pass
whiteyaris is offline   Reply With Quote
Old 05-28-2011, 03:46 PM   #120
NEexpat
Drives: 2009, auto, 4dr LB
Inspired by PYM's setup, I just finished mounting my Ultra-Gauge and Garmin Nuvi 250 in my drivers side glove box on a small rectangle of bent plexiglass.
At the proper angle and with the GPS on the left side (to avoid the hinge) I am able to close the lid without modification, I simply chased the wires out the front along the the steering wheel column and behind the drop panel where my key less entry module is located. Out of sight with the lid closed.
I don't use the GPS that much so when not in use I simply coil the wire up behind the Plexiglass mount.
As a side note for anybody wanting to mount anything here, I used Scotch All Weather Fasteners, applied to the plexi and the units.
These are not Velcro/hook and loop, they are in fact hook and hook and really "lock" the units to the mount. There is no "play" whatsoever like one would usually get with standard Velcro.
Cheers
NEexpat is offline   Reply With Quote
Old 05-28-2011, 04:06 PM   #121
Zebra
Zebra's Avatar
Drives: Yaris HB
Mine contains a window rag, some chewing gum, $1.75 in change and a 2-quart bag of sheetrock screws and roofing nails just in case I get in a high-speed chase with the cops. (I know, it's futile but it's sure tempting sometimes)
Zebra is offline   Reply With Quote
Old 05-28-2011, 06:18 PM   #122
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
that's where I keep my pot.....no seriously, it is.
I put in a tach a while back and it is retartedly bright. I put in a potentiometer and I keep it in the dash so that I could adjust it if I wanted to. I need to buy a fancy little black knob for it now though.
up close
BEEF is offline   Reply With Quote
Old 05-30-2011, 11:45 AM   #123
Idahotom
I moved my Sirius docking station to in there after reading this thread, it is a perfect use for it with room to spare. Plus the display is easier to read being in the shade. Thanks for the idea!
Old 08-07-2011, 12:31 PM   #124
vdubs4ever
vdubs4ever's Avatar
Drives: Red '08 3 Door
I put an iPod mount I had from ProFit Intl., just 3M taped it to the bottom and I keep my iPod there when its not being used and I plan on keeping it there when I get the interface. Plus I put my house keys there when I'm at work.
Mors Certa, Hora Incerta, Memento Vivere
vdubs4ever is offline   Reply With Quote
Old 08-07-2011, 12:37 PM   #125
vdubs4ever
vdubs4ever's Avatar
dont spill your coffee then
Old 08-09-2011, 09:34 PM   #126
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Hey me too......I meen my bible......lol
Extra parts? (Or where do these plugs go) jah General Yaris / Vitz Discussion 6 05-01-2006 10:33 PM
