Old 07-24-2010, 10:52 AM   #1
End of Comprehensive warranty...
so my yaris turns 3 at the end of the month and im taking it in tuesday for the pesky clutch squeaking problem (so its documented before its leaves warranty - - i've already had it "fixed" twice)
they want to charge me $99 to look over the car to see if there are any problems that can be fixed under warranty.....but i doubt it worth it.
are there any problem areas i should look at for warranty sake before i bid adieu to my comprehensive warranty?
Old 07-24-2010, 11:14 AM   #2
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
a/c is the only area because most everything else as you know is going to be wear and tear at this point......brakes, locks, window motors ( if you have them ), etc....
Old 07-24-2010, 11:20 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
The rear hatch lift supports and the battery.
Old 07-24-2010, 11:46 AM   #4
lol, if i had a/c, power locks or power windows it'd be worth looking at
brakes are practically new with echo_hrs's old calipers....
right, the rear hatch supports....i might mention that to them....i had the same problem in my matrix, but replacing them just prolonged the inevitable suckage of more oem ones
ill have them look at the battery...
Old 07-24-2010, 12:24 PM   #5
MUSKOKA800
MUSKOKA800's Avatar
You could likely go to Parts Source or Napa and get a free load test done on your battery before visiting the stealership. No point in paying them to tell you it's fine.
Old 07-24-2010, 01:02 PM   #6
auxmike
auxmike's Avatar
Hatch supports; do you mean the black gas rods? Do they fail quickly?
Mike seem fine.....
Old 07-24-2010, 10:41 PM   #7
Shroomster
Shroomster's Avatar
that is a wear and tear part....unless you know how to make a cell go bad....
and damnit how did I know you had a bare bones model? lol
I would say then:
- waterpump weepage possibly (unless you have the after market pulleys, you might even get away with having aftermarket pulleys)
- any of the black plastic outer body parts (like the side-view mirror area) warped/shifted/creaking/loose? we had the one in front of the mirror assembly replaced, the one that looks like a 'D' ; clips were very loose
- underbody rust?
- any of the interior panels shifting or creaking....they can install a foam kit or two....
Mike seem fine.....
the ones in the wife's car spouted internal leaks no oil on the pistons (i.e. they would raise the hatch halfway and you had to lift it the rest of the way up...)
Old 07-25-2010, 06:25 AM   #8
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
$99 aint that expensive if they find something thats going to fail in the near future.
Old 07-25-2010, 08:09 AM   #9
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
Wish i they had offered me that for my car. I say the alternator, and the abs speed sensors.
Adriaan is offline   Reply With Quote
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 10:43 PM
quick warranty question enobmort42 DIY / Maintenance / Service 10 08-25-2010 02:51 PM
Factory warranty + warranty extention pip General Yaris / Vitz Discussion 12 07-25-2010 05:18 PM
Warranty Information for US Yaris Owners AdeJong 03 General Yaris / Vitz Discussion 4 09-19-2009 10:14 PM
Aftermarket parts and Factory Warranty in Canada? jonathanq Canada 3 07-11-2009 12:17 PM
