Old 07-24-2010, 05:47 PM   #19
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
Originally Posted by bobolinko View Post
Well... ?
it worked...just slipped it in on the back of the socket left or right.. high beam indicator working flawlessly..
just wrapped it up with electric tape right after.
Old 07-25-2010, 04:41 AM   #20
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
Right On !!
bobolinko is offline   Reply With Quote
Old 09-27-2012, 10:55 AM   #21
neil.pillay
Drives: toyota conquest
My 12v must be quite different in Hawaii......
I connect 12v thru a 10K 1/4w resitor DIRECTLY to GROUND and it just gets a teenie tiny bit warm.....
Oh well..... Hawaiian 1/4 watt resistors are just plain TOUGH, I guess.
BTW: here's a Calculation of the circuit 12v through 10K
12 ----- Voltage or volt E or V = volts V
0.0012- Amperage or current I = amperes, amps A
10000 - Resistivity or resistance R = ohms Ω
0.0144- Wattage or power P = watts W
less than 2 hundredths of a watt.... not NEAR 1/4 watt. (Direct short to ground)
BTW, the Yaris and Scion are basically the same and the project was for my Scion. (which might be the reason for the bulb connector hi/low difference) I just thought I'd try this forum to get some help, and 2 people gave me information that enabled me to solve a very small, but vexing problem, to me.
Thanks Again Guys!
MiniTRD and CTScott U Guys ROCK !!!
I have tried this out for my conquest and it does not work.
neil.pillay is offline   Reply With Quote
Old 09-19-2017, 10:44 PM   #22
Stabicraft
Drives: 2008 BLACK YARIS
Nice. By the way, the center terminal on the connector is the high beam circuit, not the low.
Are you sure of that?
I was told, in another post, that the R/H side is the High and the L/H side is the common.
I'm fitting driving lights and need to excite the coil in the relay for the driving lights.
Please advise?
Stabicraft is offline   Reply With Quote
Does anyone know how to rewire a Low beam HID kit, for both LOW/HIGH beam use? Syroyizhka General Yaris / Vitz Discussion 1 11-30-2009 10:47 PM
HID - Even beam pattern????? fuji Cosmetic Modifications (Exterior/Interior) 8 05-30-2009 07:34 AM
Which HID to get: Bi-Xenon or Hi/Lo Beam? RSboyz Cosmetic Modifications (Exterior/Interior) 18 01-18-2009 10:47 PM
Hi & Lo Beam HID Conversion Kit OgDogg Items for Sale by private party 0 11-11-2008 04:55 PM
