Old 07-24-2010, 10:22 AM   #37
detroiter
detroiter's Avatar
You guys running 60 psi must have roads from the Kingdom of Heaven or something. No way possible you would survive Michigan roads with that setting.
I was running 44 psi and now I'm at 33 psi. The ride is much more comfortable and
much, much smoother. The bumps are alot less jarring as well.
Old 07-24-2010, 12:38 PM   #38
Hershey
same here .
Old 07-25-2010, 01:37 AM   #39
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
38F and 34R. Thats what give me the best feel.
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
Old 07-31-2010, 11:36 PM   #40
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Originally Posted by djct_watt View Post
Well, if you are heavy in your cornering, you will get heavy sidewall deflection (especially in a 60 series tire), thus wearing out the corners faster. Over-inflation minimizes this and CAN (in some instances) result in more even tire wear.
frog13 is offline   Reply With Quote
Old 08-01-2010, 02:44 AM   #41
djct_watt
Drives: 2010 NCP91 5spd
Wow, with that attitude, you must be the bell of the ball. . . ever try making a point and use arguments or is that beyond your comprehension?
Here's some PHOTO evidence for you smart guy. . .
Better yet, take your car to an autocross and bring some paint with you. Paint a white line across your sidewall and over your tread and drive. Now try adjusting your tire pressure. You'll notice that with higher pressure, less of the white line on the sidewall gets rubbed off. Tire pressure is real, and waving around a BS flag at other people rather than arguing, no wonder you have no idea about it.
djct_watt is offline   Reply With Quote
Old 08-01-2010, 02:45 AM   #42
djct_watt
^ white shoe polish also works
Tire Pressure Monitor Sensors....? 09TRD Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-19-2008 10:25 PM
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 06:53 PM
2008 Yaris with Tire Pressure Sensors nsmitchell General Yaris / Vitz Discussion 2 08-23-2007 12:34 PM
FS: Stock 15" RE92 tire GabL Items for Sale by private party 9 07-02-2007 03:20 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
