Old 08-08-2010, 11:10 AM   #109
krolos
Drives: 2008 yaris sedan
I am pretty much your average driver,maybe just a bit more on the aggressive
side, I drive some very curvy roads with some very tight curves on a regularly
basis, I find that I have to slow down alot to safely take them, it would be
nice to take them with out slowing down so much.
I like to drive these kind of roads a bit more on the aggressive side,
but not Rally style by any means.
I want to install the sway bar, what do you all think, should I get the
19mm or the 23mm? will the 23mm be to stiff for the regular type of driving?
krolos is offline   Reply With Quote
Old 08-08-2010, 02:11 PM   #110
RedRide
RedRide's Avatar
I have the23mm bar and I drive much like you do. IMO it is great for twisty mountain roads and makes navigating them much more enjoyable.
A 23mm bar is also good for a DD IMO as it seems to balance out the suspension from front to rear. It makes freewway type driving much more enjoyable and safer. It makes fast/emergency lane changes much more secure.
True a rear sway bar will appear to stiffen the rear suspension a bit. However, the stock rear it too soft (compared to the front) to begin with. A 23mm bar stiffens the rear suspension just the right amount amount IMO.
I would just add that it you have less that good tires, it will limit the cornering performance. I originally had the less than desireable "Goodyear LS" tires. When I installed and broke in my "Yokohama Avid TRZ" tires, I was finally able to reall enjoy the sway bar's cornering ability.
Personally, I don't feel in the least that a 23mm bar is too stiff.
Old 08-08-2010, 02:36 PM   #111
'LilRedYaris
'LilRedYaris's Avatar
Drives: 2007 Yaris Sedan
Send a message via Yahoo to 'LilRedYaris
The only reason I didn't choose the 23mm was worries that it might do a little too much and make driving difficult/scary in Minnesota winters. The 19mm seems to do an excellent job for me.
'LilRedYaris is offline   Reply With Quote
Old 08-08-2010, 03:01 PM   #112
RedRide
RedRide's Avatar
The 23mm bar was fine in in the last NY winter.
Anyway, either one will be much better than nothing.
Old 08-09-2010, 01:21 PM   #113
detroiter
detroiter's Avatar
Why would the 23mm be scary in winter? You shouldnt be driving that fast through winter weather anyhow for it to make much of a difference :P
Old 08-09-2010, 06:54 PM   #114
'LilRedYaris
Obviously. I just figured for me, it would be a bit extreme for daily use and wouldn't be ideal for winter or slick conditions (even going slowly). But, maybe my assumptions were wrong. I'm happy w/ the 19mm though & in the end it's what you're happy with that counts.
Old 08-09-2010, 07:08 PM   #115
RedRide
RedRide's Avatar
Yeah, either one is fine.
I just want to dispel the idea that the 23mm bar is somehow less than safe.
Old 08-09-2010, 07:46 PM   #116
sickpuppy1
Drives: 2010 Yaris Sedan
Well, from what I've heard, with the 19, when you get to the edge of adhesion you notice it more, and the car would still have a tendency to understeer. With the 23, and keep in mind this is only "what I've read" it gets to the edge and has more of a tendancy to have the rear let loose? or oversteer. Maybe he was thinking it wa gonna do that in the snow. But seriously if you are pushing it like that in the snow, a swaybar isnt gonna cause or save your butt, your just gonna get what you deserved ya know?
Old 08-10-2010, 12:20 AM   #117
detroiter
detroiter's Avatar
I was just razzin you lilred, no problems at all :P
I've had the 19mm Trd bar and now I have the 23mm UR one, I can say that
sick puppy does seem to have it on the money from what I've felt. The 19mm
felt a bit more forgiving, like you could sense it a bit more if it was getting
too out of hand and with the 23mm, you can push it harder but along with that
naturally, you get close to the limit without feeling it, which in turn makes the
threshold that much thinner.
Old 08-10-2010, 07:05 PM   #118
'LilRedYaris
No worries. :) I can vouch that there's definitely more stability in crosswind situations with the bar. It's stormy here today and the wind was howling on my way home from school. I could tell the Yaris was getting pushed around a bit but, there's a very noticeable difference now. I don't have to keep a tight grip on the wheel & constantly battle the wind anymore. Makes for a much more relaxed driving experience. Why Toyota doesn't install the rear sway bar stock is beyond me. The car's so much more driver friendly after the install. It's a relatively cheap mod to get though anyhow.
I think it actually makes me wanna drive the Yaris more, like even when I don't need to.
Old 08-10-2010, 08:03 PM   #119
so it can be a $13000 car, probably. Same with the center console, a tach (until last year), foglights, etc.
Old 08-10-2010, 08:42 PM   #120
sickpuppy1
Exactly right, Everything Toyota "should have" thrown in as standard drives the cars base price up.
You gotta remember what the car was designed for,versus what we do with it. I really dont think they had trying to pull .9 g's in a corner in mind when they built it (or 12.8 in the 1/4 mile, lol) I personally am happy with what they built and enjoy adding only and exactly what I want as I can afford it.
Old 08-10-2010, 10:15 PM   #121
RedRide
RedRide's Avatar
Years ago, Ford admitted that it only cost them about $500 more to build the "Galaxy 500" over the "Pinto".
However, they charged thousands more for the "Galaxy 500.
All auto maufacturers dumb down the entry level cars so they can justfy the high price for the more expensive models.
IMO, this is exactly why they chose not to include a rear sway bar in the yaris and gave it a beam axel.
Old 09-21-2012, 07:30 PM   #122
petyanca
Drives: 09 LB, 3 door, auto
Had the Ultra Racing 19mm rear sway bar installed on my sedan today. Huge, huge difference. Luckily, I got to test it fairly thoroughly today too. The Yaris is definitely tighter and surer on the road now. Steering and cornering are almost effortless. All I can say is: "Wow!". Kudos to Garm @ Micro Image for providing great products, customer service & support. Digging my YW T-shirt too.
How does the bar attach to the body ?
petyanca is offline   Reply With Quote
Old 09-21-2012, 07:32 PM   #123
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
It bolts underneath the car in the rear connecting the two perches of your torsion beam and runs along side that torsion beam. It bolts at the same location as the struts.
Old 09-23-2012, 06:08 PM   #124
petyanca
Got it, I didn't realize that beam twists and thought a sway bar should attach to the cab itself. Now where can I get a 23mm sway bar? My yaris is stock and I don't like how it rolls side to side on twisty roads.
Old 09-23-2012, 06:29 PM   #125
You mean shock
Old 09-29-2012, 03:08 AM   #126
trdvvti07
Where's my crown?
trdvvti07's Avatar
Drives: 07 self proclaimed TRD Sedan
i need increased g's on jug handle turns
I feel the car twirking beneath me at 70mph around these jug handle turns... Looking for undercarriage ideas to stiffin out
I am the obvious resolve to the age old question, "What happens when an unstoppable force meets an immovable object?"
trdvvti07 is offline   Reply With Quote
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 07:43 PM
Progress 22mm Rear Sway Bar PRE-ORDER SPECIAL 03Z33 Items for Sale by private party 85 04-13-2007 12:48 PM
Sway Bar! dngz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 55 01-12-2007 04:31 AM
sway bar Lowfront Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 10-18-2006 09:51 PM
Sway bar chrisada_to2a Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 09-05-2006 08:34 PM
