Old 08-15-2010, 11:53 PM   #1
longlivekel
Drives: Rover Mini S
Which Clusters Interchange?
Hey guys.
I have a 2009 loaded yaris 5 spd. It doesnt have the da.mn tach!
I have ABS no Traction control.
Which ones are interchangeable?
Sedan interchangeable?
I want one with a tach.
longlivekel is offline   Reply With Quote
Old 08-18-2010, 08:10 AM   #2
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
There is a big thread on this, I can't find it but search and you will find your answer. If I find the thred I'll link it to you.
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 08-18-2010, 09:04 AM   #3
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Do you drive a sedan or hatchback? I'm a bit confused.....
You can change the the sedan cluster with another sedan cluster only. A 2009 sedan cluster with a tach will fit your in your car. I dont know if a 2007 or 2006 cluster with a tach will work w/ your 2009 car....
If you have a 2009 hactback, a 2009 or 2010 cluster with tach will work on your car. Dont use 2008 cluster with tach on your hatchback, because it may not work.
ebay usually has some sedan cluster tachs for good price.
Old 08-18-2010, 09:15 AM   #4
longlivekel
Woops sorry dudes.
I have a Hatch..
I search the forum and couldn't find it. But the sedan prob won't fit.(my guess)
Old 08-18-2010, 11:00 AM   #5
cdydjded
Drives: Yaris LB Turbo
Hatchback & Sedan clusters are not interchangeable. If you have a HB you need to use a cluster from a HB. If you have a Sedan you must use a cluster from a Sedan. Canadian cluster will work, it will read your speed in KM, & the mileage will be from the car the cluster cam out of. Also FYI, in Canada our Yaris came out in 2006, so when searching for a cluster start with that year instead of 2007.
cdydjded is offline   Reply With Quote
Old 08-18-2010, 11:07 AM   #6
Revsson
Some reading found here:
Gauge Cluster Swap
Read it all the way through. Some pros, some cons.
Or just search for swap, cluster, tach and you will get a few more threads
about issues with the swap.
Old 08-18-2010, 01:54 PM   #7
longlivekel
All questions answered. Thanks a bunch guys!
interchange between 09 Yaris and 09 Corolla drachenv6 Performance Modifications 3 07-25-2009 02:37 AM
Gauge Clusters Nutzoids Cosmetic Modifications (Exterior/Interior) 16 03-26-2007 11:35 PM
scion header interchange? bladesmith6 Performance Modifications 36 12-17-2006 08:51 AM
