Old 09-10-2010, 02:50 PM   #1
rep1158
Drives: 2010 yaris 3 door stick
trans seal leaking
I have 2010 Yaris with 22,000 miles on it. Just in for inspection. Mechanic says left outer trans seal leaking. Should be covered under warranty. Is this a common problem for the Yaris? Is this a recall matter??
any help appreciated!
thanks
rick
rep1158 is offline   Reply With Quote
Old 09-10-2010, 05:04 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
get a socket and tighten it is should close the gaps..i did the tightening on my celica 2x 70k clicks interval it got rid of the leaks.
Old 09-10-2010, 05:14 PM   #3
Lucas13
Drives: 07 Yaris LB
thanks
rick
I think we are taking about the axle seal, this is a common problem on this cars, I got mine replaced under warranty and after a little while the main shaft started leaking too so they ended up replacing the whole transmission. just take it to your dealer so they can replace it for you, your transmission and engine is covered up 60k
Good luck!
Lucas13 is offline   Reply With Quote
Old 09-10-2010, 09:29 PM   #4
marcus
toyota
marcus's Avatar
tranny and engine is covered 5 years or 100k..
Old 09-11-2010, 12:08 AM   #5
sleey0
Drives: 2008 Yaris LB
One of you is speaking in Toyota America language and the other is Toyota Canada. lol
US is 5/60k for Powertrain.
sleey0 is offline   Reply With Quote
Old 09-11-2010, 10:57 PM   #6
bankrobber
Drives: 2007 Yaris Hatchback
Also depends on the dealer. I bought mine used and it came with balance of factory warranty and also 10 year or 100k powertrain warranty supplied by the Toyota dealer I bought from
bankrobber is offline   Reply With Quote
Old 09-12-2010, 11:24 AM   #7
marcus
toyota
marcus's Avatar
oh i didnt know that..wow 60k seems too short
Old 09-12-2010, 11:34 AM   #8
sleey0
60000 miles, not km.
Old 10-26-2010, 10:14 PM   #9
lilj4321
Drives: HB Toyota Yaris 07 VVT-i
change tranny as soon as possible!!!!!!!!!! before it blows up!
lilj4321 is offline   Reply With Quote
Old 10-27-2010, 12:56 AM   #10
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
Other than some forum chatter, there have been no consistent reports of problems with this vehicle and it is top rated for over all reliablity by several tracking sites for it's class. The vehicle is mass produced, there may be some failings for any number of reasons. In 50K miles of driving I've been lucky enough to have no problems.
UTVitz is offline   Reply With Quote
Old 10-27-2010, 08:35 AM   #11
chilly79
Drives: 09, 3dr, LB, Carmine Red
Left side seal went out at 35,000 miles on my 2009.
chilly79 is offline   Reply With Quote
Old 10-27-2010, 09:29 PM   #12
Lil Abner
Drives: 2009 3dr LB Manual
My 2009 had a seal that was leaking (left axle seal). I cleaned it to confirm. 5,000 miles later, hasn't leaked again. If you see it leaking, take it in to get it done under warranty.
Old 10-29-2010, 09:48 PM   #13
az_saguaro
What to Mod Next?
Drives: 2008 3Dr HB, Bayou Blue
My left axle seal on my manual tranny started leaking at 40k. Had it replaced under warranty. Now the car is back in the shop for a bad 3rd gear synchro. This is my first Toyota and I am not impressed with the tranny.
az_saguaro is offline   Reply With Quote
Old 08-06-2012, 04:55 AM   #14
En4sir
En4sir's Avatar
Drives: '09 Yaris 3dr HB 5sp
My drivers side axle seal has begun to leak on my 2009 hatchback (it has 110K miles on it). My dealer says a leaky drivers side axle seal is semi-common. $159.00 plus tax for parts and labor. Considering this is the ONLY hiccup I've had with this car I can't complain at all. I replaced the tires at 70K and I still have the original brakes.
"Never argue with an idiot. They drag you down to their level, then beat you with experience."
En4sir is offline   Reply With Quote
Old 12-07-2012, 10:48 AM   #15
Ravenight
Drives: 2008 Yaris SE
driver's side axle seal
2008 manual transmission Sport edition, has 110k. Dealer informed me of a driver's side axle seal leaking. Took a look at it and it looks like a weep, but should I be worried? If I check my trans fluid regularly, is this a problem?
Ravenight is offline   Reply With Quote
Old 12-07-2012, 11:48 AM   #16
bronsin
bronsin's Avatar
Not a weep isnt a problem.
And I wonder what everybody means by "Leak"?
A real hairy chested gusher is for concern but as long as you maintain the level not a problem.
Old 12-08-2012, 01:33 AM   #17
yaris2010RS
yaris2010RS's Avatar
my driver side seal went shortly after they replaced the CV shaft due to the boot leaking.
other then that has been fine.
SuperTech trans fluid (auto trans) detroiter DIY / Maintenance / Service 11 08-20-2010 08:50 PM
Axle seals leaking caused by lowering ride height? NH3R717 DIY / Maintenance / Service 2 07-22-2010 03:29 PM
Auto trans : Drive to Park + Handbrake : was not in park... Maxh91 General Yaris / Vitz Discussion 7 06-11-2009 06:37 PM
Effects of too much trans fluid in the case? (auto trans) detroiter General Yaris / Vitz Discussion 5 02-24-2009 11:08 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
