Old 07-31-2009, 07:46 AM   #1
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
Help: Rear Door Small Window Install
Hi guys/gals,
I posted the other day my story of having my car broken into. They smashed in through the small window in the right rear door (luckily). I'll be picking up my replacement window and rubber surrounding today after work. I checked through the Window Glass PDF repair manual but that's the only window it doesn't cover. I was hoping someone on here has some good instructions on how to get this window in.
By the looks of it, it should only need to be popped in and maybe use my finger or a hard piece of plastic to go around it, pulling the rubber through one side.
Any help or suggestions would be GREATLY appreciated. Thanks!
..:'; Nick ;':..
2008 Yaris Sedan - Flint Mica
Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter
nick.dollimount is offline   Reply With Quote
Old 07-31-2009, 09:57 AM   #2
Sparks Toyota-TRD
Drives: Toyota/Scion
Shoot me your email and I might have something for you!
Tim
Sparks Toyota-TRD is offline   Reply With Quote
Old 07-31-2009, 10:05 AM   #3
nick.dollimount
Yaris = <3
PM sent, thanks!
..:'; Nick ;':..
Old 07-31-2009, 12:54 PM   #4
supmet
Drives: 2007 4 Door Yaris
Check in here.
http://www.etimago.com/yaris/repairm...ow%20Glass.pdf
Here is what I did in my corolla - not sure if its 100% the same. Basically, I rolled the window next to the quarter glass down, removed the rear door panel, unscrewed a bolt holding the frame in between the rear window and the rear quarter glass, and then you should be able to wiggle that frame enough to squeeze the quarter glass in. Straighten out the frame, bolt it back in, reassemble the door and make sure your window still rolls up.
Old 07-31-2009, 01:47 PM   #5
nick.dollimount
Yaris = <3
Originally Posted by supmet View Post
Check in here.
Thanks for the tip! That's going to be easier than the manual saying to take things right apart
..:'; Nick ;':..
Old 08-02-2009, 01:08 AM   #6
nick.dollimount
Yaris = <3
Got this put in with bot your guys' help! It's looks factory =D AND it was fun doing it! Thanks guys!
..:'; Nick ;':..
Old 09-22-2010, 02:17 PM   #7
paulbradley
Drives: toyota yaris sedan (silver)
where did you get your replacement window from?
paulbradley is offline   Reply With Quote
Old 09-22-2010, 02:22 PM   #8
nick.dollimount
Yaris = <3
I ordered it right from the dealer.
..:'; Nick ;':..
Rear Window Removal idipudipwedip2 DIY / Maintenance / Service 1 03-27-2009 05:09 AM
CAN TOYOTA RETROFIT NON-FIXED REAR WINDOW? pennsylvania girl Cosmetic Modifications (Exterior/Interior) 8 04-22-2007 01:47 AM
Install of tweeters in the rear???? jdubau55 In Car Entertainment + Electronics (audio / video / alarm) 54 03-09-2007 07:44 AM
