Old 10-08-2010, 02:28 PM   #1
nikvolkert
Drives: 2008 yaris
does defrost mode affect mileage?
i have noticed that the car runs significantly cooler when it is in the defrost/defog mode rather than the other settings. ( i usually don't even need to turn on the ac even on really warm days).
i just thought that the may be the possibility of the car automatically running the compressor part of the time or something like that.
if this is the case i imagine i should stop leaving it in the defrost/defog mode to save some mpgs.
nikvolkert is offline   Reply With Quote
Old 10-08-2010, 03:18 PM   #2
In that mode the compressor is automatically on (unless you do the DIY to unlink that mode from hitting the switch for AC), so you definitely burn more fuel when the knob is turned that way.
Old 10-08-2010, 05:36 PM   #3
STC
"LibertyRides!"
STC's Avatar
^ Yeppers!
~ Mark ~
Old 10-08-2010, 05:55 PM   #4
BailOut
Steals terrorist's lunch
BailOut's Avatar
To avoid the MPG hit but still enjoy some defrosting, simply keep the upper heater vents on and open one front window a bit. A sort of evaporation/sublimation occurs which clears off the windshield.
I have found that it takes a hand or two of opening to clear it but then just a few inches to maintain it.
- Brian
Share the Road
Old 10-08-2010, 09:50 PM   #5
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Thanks for the tip Brian!
-The Fitful One
Old 10-17-2010, 09:23 AM   #6
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I've noticed on my Echo that selecting the foot or lower vents only still sends air up to the windshield, so I never turn it to full defrost unless it's really humid out and the windows won't dry up.
Anyone notice this on the Yaris? I know this little cheat doesn't work on my parent's Matrix.
Old 10-18-2010, 01:32 AM   #7
yaris2010RS
yaris2010RS's Avatar
i will definatly try that in the morning.....
Old 10-19-2010, 10:50 AM   #8
33OH
Drives: '08 Yaris
Yep, this works. I run the "foot" mode all of the time to defrost the windshield.
Old 10-19-2010, 11:42 AM   #9
yaris2010RS
i tried mine and some air does go to the window but not alot...... i will try it next time i need the defogger and see if its an acceptable amount of air flow to defog/frost the window
Old 10-19-2010, 12:06 PM   #10
Bluevitz-rs
yeah it isn't a tonne of air, but I've found that using the A/C to defog the windows, you have to keep using it or the moisture taken out by the A/C core gets sent back into the car the minute you turn it off.
Old 10-19-2010, 12:30 PM   #11
33OH
Drives: '08 Yaris
Unless you leave it in fresh air mode.
Old 10-19-2010, 01:50 PM   #12
Bluevitz-rs
No, regardless of using fresh or recirculated air.
Old 10-19-2010, 01:52 PM   #13
33OH
Drives: '08 Yaris
Oh, I never have to move mine off of Fresh air + Foot even in the off position. It automatically defogs the windows for me. If I change it to re-circulated air, that's when the windows fog up.
Then again I do have a leaky car (water comes up through the floor), so maybe my constant fighting of fog is different than what we're talking about.
Old 10-21-2010, 12:56 AM   #14
Ryu
I just tried the what so called " foot mode" and it works!! It does however send limited amount of air to windshield to clear up the fog, Is it best to to go for coldest air rather than hot air to clear up the fog on windshield faster?
Will the "foot mode" activate the air conditioning?
Old 10-21-2010, 01:18 PM   #15
Bluevitz-rs
No foot mode does not. Only the two settings with defrost and defrost/foot. And go with warm air to defog the window. Once the windshield is warm, moisture won't condense on it anymore. Plus, warming cold air lowers the humidity level of the air itself, as cold air can not hold as much moisture as warm air can.
Old 10-21-2010, 11:39 PM   #16
Ryu
Thanks Bluevitz-rs
-Mileage Thread- -Log your mileage, year, model, color, any problems here... Kal-El DIY / Maintenance / Service 322 07-20-2016 11:07 AM
Does Gas Mileage Increase After 1st Oil Change? ChilliwackGuy Fuel Economy Forum 10 08-04-2010 03:13 PM
2009 Yaris Mileage wornways Fuel Economy Forum 3 07-29-2009 12:42 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 09:53 PM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 01:32 AM
