Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Australia
Old 10-26-2010, 01:06 AM   #1
amanda_84
Drives: 2010 Toyota Yaris YR
Send a message via MSN to amanda_84
Temperture sensor + fuel consumption on YR
Hi,
I bought a 2010 YR base model hatch and I can see the space for the temperature reading and the fuel consumption on the dash where the clock is but it doesnt work - I think this is because i've only got the base model.
Does anyone know how to 'turn on' this feature?
amanda_84 is offline   Reply With Quote
Old 10-26-2010, 08:55 AM   #2
There's no way to turn it on for AUS market cars. That same cluster is used in Japan, and in that market the feature is enabled.
Old 10-26-2010, 07:34 PM   #3
amanda_84
That sucks, you would think if they use the same cluster and theirs is 'on' then there would be a way to turn it on and off for here.
Oh well..
thanks for the reply
Old 10-27-2010, 11:15 AM   #4
hazzy
Drives: Yaris YR
I've read up on the manual, apparently they are for the cruise control option.
So I guess if you have the cruise control package, it should work....
hazzy is offline   Reply With Quote
Old 10-30-2010, 09:39 AM   #5
Al_
Al_'s Avatar
Drives: 2010 1.3L man
With the temperature most cars have dumb gauges anyway so our warning lights are an acceptable substitute.
Cruise information would be handy though.
Al_ is offline   Reply With Quote
Old 03-20-2011, 10:29 PM   #6
DP1975
Drives: 2010 1.3 YR
Hi All
I recently bought a YR 2010 model as well, so just to confirm (apologies if this is a very silly question) there are warning lights if the engine gets overheated? Would the warning light be the same as the "cool" light that comes on when you first start the car in the morning? Just a different colour?
DP1975 is offline   Reply With Quote
Old 09-01-2012, 09:21 PM   #7
chanka
Drives: Toyota allex
Hi there,
When engine in cold coolent temp green light will come. But when engine nearly over heat there is a red symbol next to cold indicator that shows U to stop soon.
chanka is offline   Reply With Quote
[D-4D] increased fuel consumption and black smoke barmagan DIY / Maintenance / Service 10 09-20-2014 12:21 PM
fuel consumption calculations jumping up and down... adigilani DIY / Maintenance / Service 4 05-12-2010 03:32 PM
Fuel Consumption Calculator taka Fuel Economy Forum 0 10-11-2009 09:16 PM
Oil consumption bear4 General Yaris / Vitz Discussion 5 01-02-2009 04:17 AM
