Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Caribbean
Old 10-26-2010, 09:03 AM   #19
TunTun_yariS[PR]
Drives: Vios 10'
jajaja A NITROSO Las HB Produceennnn....
TunTun_yariS[PR] is offline   Reply With Quote
Old 10-26-2010, 11:12 AM   #20
jouna
jouna's Avatar
Drives: jdm yaris sedan
dejame desviarme un pokito pa hace la tradicion de desviarse del thread jaja ..
la camcom setea la mezcla tambien? o es el vvti na mas? pq si tambien hay la opcion de la mezcla seria un exito y bregaria mas q la apex neo
vvti bregao!
jouna is offline   Reply With Quote
Old 10-26-2010, 12:50 PM   #21
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
http://www.powerenterpriseusa.net/pr...con/camcon.htm
CAMCON CC-111
The CAMCON-T allows you to take unrestricted control of your VVT-i valve timing into your own hands. Along with this, the ability to control your A/F will allow you to more efficiently and precisely tune your vehicle giving you a higher level of performance and fuel economy.
TOYOTA VVT-i & VVTL-i
The CAMCON-T controls the VVT-I timing +/- 20 degree in 15 different points of 500rpm increments within 2000rpm to 9000rpm Range.
A/F is controlled -10% to +20% in 17 different points of 500 rpm increments within the range of 1000rpm to 9000rpm. Easy Installation
Si no me equivoco, si t deja controlar A/F ratio ;)
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 10-26-2010, 02:01 PM   #22
mario98c
mario98c's Avatar
La camcon te deja tuniar el A/F y el vvti y brega asegurao en los yaris.
Old 10-26-2010, 04:03 PM   #23
JENS07
JENS07's Avatar
Drives: Yaris 3 Door HatchBack S 2007
Send a message via ICQ to JENS07 Send a message via AIM to JENS07 Send a message via MSN to JENS07 Send a message via Yahoo to JENS07
Me siento que me tiran a mi!!!! pero yo trankilo!
"Just take a time to think"
JENS07 is offline   Reply With Quote
Old 10-26-2010, 06:41 PM   #24
jouna
jouna's Avatar
duerma trankilo jens que usted es la unica hb que puede hablar entre sedanes jaja... y segun mec. Campito camcom all the way le sacaron 15 hp y 23 de torque sin araña que con la araña se le puede sacar un poco mas por que casi siempre somos jodones pa tuniar pq siempre tamos rich. nunca x admitir mucho aire asi que habrire un thread pronto con la camcom con dyno time con todo los detalles
vvti bregao!
Old 10-26-2010, 08:01 PM   #25
Nanoss22
Drives: Yaris sedan 10 std...
Cmo cuanto sale ese inventito.....
Nanoss22 is offline   Reply With Quote
Old 10-26-2010, 08:58 PM   #26
jouna
jouna's Avatar
bueno la compu se puede conseguir kmo en 250 y instalarla 60 o menos setearla kmo 30 pesos y el dyno son kmo 35 la hora pero campito se tarda kmo media hora nada mas setiandola.. es un proyectito pero vale la pena
vvti bregao!
Old 10-26-2010, 10:38 PM   #27
yaris_trd
Drives: toyota yaris hb
bno papa con ese huevito es que les voy dar la pasea del siglo sigan q los sedanes tan kedaos jajaja
yaris_trd is offline   Reply With Quote
Old 10-26-2010, 10:38 PM   #28
xen555
xen555's Avatar
Drives: 3 DOORS LB
y esa araña cuanto como donde?
xen555 is offline   Reply With Quote
Old 10-26-2010, 10:53 PM   #29
mario98c
mario98c's Avatar
jeje vamo allax a ver si los sedanes están kedaos
Old 10-26-2010, 11:14 PM   #30
Nanoss22
Bueno si ronkamos es pq podemos jaja y nosotros corremos sin bregar el motor no Nos in here....
Old 10-26-2010, 11:53 PM   #31
JENS07
JENS07's Avatar
Graxx Jouna!!
Old 10-27-2010, 12:30 AM   #32
Nanoss22
La vi en clasificadosonline 250...
Old 10-27-2010, 11:49 AM   #33
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
No tengo un avion, pero se mueve entre los Yaris. So me avisan y c da el pase
Old 10-27-2010, 11:51 AM   #34
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
fallo
off topic (cm siempre hacemos en tooodos los threads)
cual era la manga q te dijeron q reconectaras pa' evitar q el carro tumbe (osea q se active el fuel cut-off) Llevo dos dias corridos con la jodienda esa dandome candela
Old 10-27-2010, 02:37 PM   #35
jouna
jouna's Avatar
diablo si no puedo contar las veces q el carro tumbo bajando del meet
vvti bregao!
Old 10-27-2010, 05:06 PM   #36
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
No c el tuyo pero el mio tumba d d 3ra pa' 4ta... Y no es pq llega a las 118mph :/
Asi quedaron los aros! inthecaribbean Caribbean 17 08-11-2010 07:35 AM
Para los Amantes de los VideoJuegos paveovisual Caribbean 0 11-30-2009 12:58 PM
Los Yaris son los mejor pero.... vertigo366 Caribbean 29 08-28-2009 09:59 PM
suspencion ajustable fyaslin26 Central and South America 1 11-29-2008 03:58 AM
Ski Dazzle® - The Los Angeles Ski Show & Snowboard Expo ® Malaya1221 Off-topic / Other Cars / Everything else Discussions 0 11-26-2008 07:02 PM
