Old 11-21-2010, 03:33 PM   #37
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
I'd take pics of the tools I made, but you shave down the edges of a wrench to fit it in there easier.
The crow foot is if you cut a box wrench in half and use the closed side and weld a socket on there so you can turn it with a ratcheting wrench. I don't know how to explain this better than that.
Old 11-21-2010, 05:54 PM   #38
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Originally Posted by Bluevitz-rs View Post
I just had another idea as to the case of the backup on the return.
Everyone is thinking the return is too restrictive. Well has anyone considered there's a restriction in the PCV valve? If you had a build up of pressure in the crankcase, if the pressure isn't getting out the PCV valve there's only one other option, the drain line for the turbo.
Or as the cars get older, the dip sticks pop out.
This would be why most factory turbo cars have two breathers on the rocker cover, one with the pcv to the plenum, the other back to the intake before the turbo.
rob323 is offline   Reply With Quote
Old 11-25-2010, 08:33 PM   #39
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Done.
More pics to come after Turkey dinner.
Old 11-25-2010, 09:01 PM   #40
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Holy shit!
Yoda is offline   Reply With Quote
Old 11-25-2010, 10:20 PM   #41
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Looks great.
How'd you mount the intercooler?
Focus_Sh1ft is offline   Reply With Quote
Old 11-25-2010, 11:43 PM   #42
PETERPOOP
PETERPOOP's Avatar
For the AEM meth injection squirter/nozzle, a hole was needed to be drilled to fit it. We slightly bent the pipe so the nozzle could squirt towards the throttle body.
Oil catch can installed..
For the intercooler, it was mounted with some brackets we made for the bottom. Some plumber's tape was used for the top. It was kinda hard to make the intercooler centered, but we got it as close as we could.
Top shot..
Old 11-26-2010, 12:12 AM   #43
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
much better looking piping than the Greddy kit for the xA/xB
Originally Posted by xnamerxx
you nailed it sir.
Old 11-26-2010, 01:06 AM   #44
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^ for sure!!!
Looks awesome. I still can't figure out why the intercooler has an offset outlet? It looks weird.
Old 11-27-2010, 01:34 AM   #45
PETERPOOP
PETERPOOP's Avatar
Thanks guys. This a very short clip of the turbo flutter that happens when shifting. Taken with a junk camera. Expect MUCH MUCH better quality videos once I am tuned.
I am running 14.5 (lean) during WOT, so I haven't been driving the car around that much. It also drives at 15.0 during normal driving conditions (a little lean), and idles from lean to rich. Definitely needs a new tune right. Waiting for the AEM tru boost controller to show up before the tune happens. Mind you, this is running with my supercharger tune that I still currently have. Not sure what kind of AFR numbers you'll get, pretuned, if you didn't have management from the start.
http://www.youtube.com/watch?v=BWiamyiPFhQ
Old 11-27-2010, 02:34 AM   #46
Nexus1155
Drives: Audi
Anything outside of boost, 13.5-16.0 is acceptable, mostly it tries to stay stoich at 14.7.
You are also running a non recirculated BOV it seems, you can see the AFR gauge go rich when the BOV pshhhts.
Boost you should be at 11-12.
Hope you get someone to tune it good for you!
Old 11-27-2010, 02:13 PM   #47
PETERPOOP
PETERPOOP's Avatar
Just pulled out the old spark plugs, look kind of worn, and the gap is at about 1.2 ( that was with the S/C ). Planning on putting on new ones (NGK Iridiums), any suggestions on a good starting point for the gap?
I'm also running meth injection under boost, will that also affect the gap?
I'm going to have the tuner gap them during the tuning session, but I don't know when I'll be able to get the car tuned. But for now, I am going to put some new ones in.
Old 11-27-2010, 03:07 PM   #48
PETERPOOP
PETERPOOP's Avatar
The 1.2 is mm, breaks down to like .045 (which is basically stock). But under boost, i was reading requires a smaller gap. Cali yaris is running .028 at IDK how many psi. I was thinking to set the gap at about .035 or something.
Any thoughts?
Old 11-27-2010, 04:00 PM   #49
.028 gap at 14 psi up.
At what boost level is your meth injecting? I tuned my car up to 14 psi before it needed the meth.
Old 11-27-2010, 04:43 PM   #50
PETERPOOP
PETERPOOP's Avatar
Put in the new spark plugs, set the gap at .035. It actually gave me better AFR. It is now running at about 10-11 AFR during WOT, and 14.7-8 during normal driving.
Here's a new short little clip of doing WOT. Click HD and full screen to see the wideband numbers better..
http://www.youtube.com/watch?v=8kXZRORS9rk
Right now I think I have the meth starting at 2psi. But when I get tuned, I am going to talk to the tuner to see when I should have it start.
Also, my current boost gauge is showing about 4.5 lbs of boost. Not too sure how accurate the gauge is. I thought the zage kit comes at 6-7lbs of boost? Going to be putting in a AEM tru boost digital boost controller in the near future. I'm going to set it at 8 lbs of boost.
Old 11-27-2010, 04:45 PM   #51
Nice!!
I have my meth start at about 6psi. I don't think you need it before that point.
The zage kit comes with 0.5 bar spring which is just a bit over 7psi.
Old 11-27-2010, 06:56 PM   #52
Nexus1155
Drives: Audi
.26-.30 gap i guess for when you boost. I guess .35 is ok. Watch for misfires, im surprised you didn't hear it breaking up before when it boosts like little pops everywhere.
Old 11-27-2010, 09:52 PM   #53
Focus_Sh1ft
I had this problem. It disappeared as soon as I put a manual boost controller in though. Now I'm seeing 8ish during normal driving. The wastegate probably cracks around 5 psi and makes it hard to spool up fully.
How's your BOV situation? I watched the second video and can't really hear it. Kinda glad to see you're having fluttering as well... So far I've fully adjusted and loosened the BOV and it still always flutters.
Old 11-27-2010, 11:11 PM   #54
PETERPOOP
PETERPOOP's Avatar
Slow drive by..
http://www.youtube.com/watch?v=ZG5K3LgsJGw
Re gapped to .030
FocusShift: Good to hear about the boost situation. All I hear is the flutter from the turbo. Can't really hear the BOV. You should post a video of yours......
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
Scion XB 1NZ-FE Turbo build xbgod Forced Induction Forum 417 07-24-2011 10:16 PM
XBG's Total Build and Update Thread xbgod Performance Modifications 10 11-19-2010 12:19 AM
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 11:08 PM
