Old 11-27-2010, 03:09 PM   #1
tomm
Drives: 02' Yaris Verso
TP Sensor, or TP Switch?
Hi, I'm wondering if the tps on the yaris is a potentiometer type sensor or if its just a simple switch with "idle contact" and "wide open throttle" contact points.
I'm after a throttle position SWITCH for my old datsun and the yaris throttle opens the correct way.
It's a 2002 model with a 1.3l engine.
tomm is offline   Reply With Quote
Old 11-27-2010, 07:35 PM   #2
krusty
krusty's Avatar
Drives: 2010 Yaris ce
The tps in the Yaris is a potentiometer
krusty is offline   Reply With Quote
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 04:11 PM
