Old 11-18-2010, 10:48 AM   #109
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
New head unit arrives TODAY!!! Yaaaaay!!!!
I'm so done with my stock HU and my battery powered Blue Tooth unit for my cell phone . After a bunch of research, I've decided on a Kenwood Excelon KDC-X994 (>>>link<<<).
It has B.T and a rear USB port (which I want in the back, not in the front so I can throw a thumb drive on it and forget about it) and for the price, it has outstanding adjustability and control over the "sound stage". I wanted something more minimalist in appearance so as not to attract thieves.
Here's a quote from the product research team at Crutchfield, these are just some of the features that pulled me over to this unit:
Sound Excellence DSP: In order to optimize the sound quality, you can use the Sound Excellence DSP to set the type of vehicle and speaker sizes, locations, distances and x-over points. The DSP settings include the following:
Cabin Setting: Choose from Compact, Full Size Car, Station Wagon, Mini Van, SUV, Mini Van (Long), or Off
Speaker Setting: The speaker X'over is automatically set when the position and size of each speaker are select from the following items.
Front: Location (Door, On Dash, or Under Dash); Size: (6-1/2", 6-3/4", 7", 4"x6", 5"x7", 6"x8", 6"x9", 7"x10", OEM, 4", or 5"); Tweeter (None or Use)
Rear: Location (Door, Rear Deck, 2nd Row or 3rd Row; Size (6-1/2", 6-3/4", 7", 4"x6", 5"x7", 6"x8", 6"x9", 7"x10", OEM, 4", or 5")
Subwoofer: Size(10", 12", 15", None, 6-1/2" or 8")
Digital Time Alignment (DTA): Choose from 0.00 to 14.44 feet for the Front pair of speakers, Rear pair of speakers, and Subwoofer distances in reference to the distance between your listening positioning and the locations of the particular speakers.
X'Over: The Kenwood eXcelon headunit provides independent high-pass crossovers for the unit's front and rear speaker/preamp outputs, as well as a subwoofer low-pass crossover.
Front High Pass Filter: Frequency (30, 40, 50, 60, 70, 80,90, 100, 120, 150, 180, 220, or 250Hz); Slope (-12, -18, or -24 dB per octave); or you can also select full-range
Rear High Pass Filter: Frequency (30, 40, 50, 60, 70, 80, 90, 100, 120, 150, 180, 220, or 250Hz); Slope (-12, -18, or -24 dB per octave); you can also select full-range
Subwoofer Low Pass Filter: Frequency (30, 40, 50, 60, 70, 80, 90, 100, 120, 150, 180, 220, or 250 Hz); Slope (-12, -18, or -24 dB per octave); Phase (Normal/Reverse); or you can also select full-range
Equalizer Control: Equalizer Control allows you to use one of the System Q presets, or set your own custom settings using the 5-band Equalizer. The EQ adjustments are as follows:
Preset EQ: You can select from Natural, Rock, Pops, Easy, Top 40, Jazz, Game, iPod (you can select from 22 EQ curve types), or User.
5-Band EQ: The User mode allows you to adjust the following 5-Band EQ (62.5Hz, 250Hz, 1kHz, 4kHz, 16kHz) settings.
Band Levels: Independent front and rear EQ level of -9dB to +9dB.
Bass Effect: Enhances the bass response of Band 1 (62.5Hz).
Position Control: For a better sound-stage you can select your optimal listening position. You can choose from All, Front Left, Front Right or Front. You can also select to manually fine tune the sound stage by selecting the distance for each individual speaker in the vehicle compared to your listening position. You can select between 0.00 to 5.58 feet for the Left Front Speaker, Right Front Speaker, Left Rear Speaker, Right Rear Speaker, Left Subwoofer and/or Right Subwoofer.
Plus: 24 Bit D/A Converter: The Kenwood eXcelon KDC-X994 utilizes a 24-bit digital to analog converter for superior CD sound quality.
Additionally, there is free sofware I can download from Kenwood for the USB device:
Music Editor Compatible: The Kenwood KDC-X994 supports the PC application, Kenwood Music Editor Lite (ver.l.0 or later). Kenwood Music Editor Lite is a desktop software that helps organize, manage and transfer AAC, MP3, and WMA music files to your USB devices from your PC. When you playback audio files that have been stored on your USB device using Kenwood Music Editor Lite (ver.l.0) through this unit, you can search a file by title, album, or artist name using the headunit's Music Search function.
This guy should really help all my other components shine! After install, I'm going to have to reset everything on the amps and re-tune the whole system. I'm actually looking forward to it! And I thought it sounded good with the stock HU!
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 11-18-2010, 12:28 PM   #110
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Congratulations!
with x-over features you only need to match gain the amps. By pass every thing else.
D.
Old 11-18-2010, 01:36 PM   #111
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
The 794 has basically the same options, i've spent about an hour of tuning and wow, these things have settings out the Ying Yang. Congrats on the buy !
Old 11-18-2010, 01:45 PM   #112
Herbicidal
Herbicidal's Avatar
Thanks guys! I'm really psyched about getting it! I've got a busy weekend ahead, but I hope to at least get it hooked up. The 'tuning' will come later.
_S7V7N_ - good luck with your tuning! Sounds (no pun intended) like you are pleased with your unit.
Old 11-18-2010, 07:09 PM   #113
Herbicidal
Herbicidal's Avatar
Originally Posted by Truchito86 View Post
wow man, i've just read your thread from the very begining, and i've got to say that all of your work is very impressive. it also help me make the decision of going ahead and getting the sound deading job started on my yaris sedan. all i've done is replaced the stock speakers with alpine type-R's, but the door rattle has always annoyed me. can't wait to get started this weekend. great write up man!
Thanks! Glad you had some time to kill! In hindsight, I think I over did it on the RAAMmat. From what I know now, looks like a 25% coverage of the RAAMmat on the inside of the door panels would kill the resonance, then go to town with the Ensolite foam. Both products are VERY easy to use and do not require gloves. I LOVE the peel and stick, that's the easiest to work with. All the door pictures are right there, so you know what's behind the panels. No big surprises, just lots of holes.
Good luck if you choose to do it. I had fun! But then again, I'm sick like that.
Old 11-18-2010, 07:45 PM   #114
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Now you guys know about some of the crossover and EQ capabilites Derick and I are faced with...
Add in a complete 1/3 Octave and another pre out...
― Thomas Paine
Old 11-19-2010, 12:11 AM   #115
Herbicidal
Herbicidal's Avatar
Yeah, I think I will stay at my level. Even with my relatively low-end components it will be the best system I've ever owned and I'm good with that. Especially since I did all the work myself.
Old 11-19-2010, 12:14 AM   #116
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I applaud the DIY work!
― Thomas Paine
Old 11-19-2010, 02:10 AM   #117
derickveliz2
There is nothing better than the feeling of doing it your self!
Old 11-19-2010, 10:33 AM   #118
Herbicidal
Herbicidal's Avatar
Yeah, I do too! You guys, however, took THAT to the next level and beyond!!! Way to go!
Old 11-19-2010, 10:58 AM   #119
Herbicidal
Herbicidal's Avatar
Oh, I did get the new Toyota bezel that gives me the double DIN opening since I have the factory integrated radio. I did a quick test fit of what came from Crutchfield and it fits the Toyota bezel perfectly! Whew! Now it should be pretty much plug and play.
Oh yeah, this little jewel (which served it's purpose) will be coming out too!
Now I'll be able to take advantage of the RCA outputs on the new deck and go right to the Eclipse amps. My little system will be able to breathe!!!!
Old 12-02-2010, 12:17 PM   #120
Herbicidal
Herbicidal's Avatar
I've installed my Kenwood HU and it has TONS of adjustability. I've barely scratched the surface. My two amps (Eclipse EA4200 and the Eclipse XA1200600W) both have adjustability for the crossover's and bass boost as shown in the pictures below. Since my new HU has built in control over ALL these functions, should I "zero out" the amps and do ALL the tuning through the HU? Looking for suggestions. Thanks!
XA-1200:
EA-4200:
Old 12-02-2010, 12:31 PM   #121
derickveliz2
In theory you would "by pass" the X-over and only adjust the Input Levels AKA Gains
In your amp I don't see an option to go "full" like in my amp.
But I'm sure the Masters will correct me if I'm wrong and give a proper answer
CLA 250, 4MATIC
Old 12-03-2010, 11:55 AM   #122
Herbicidal
Herbicidal's Avatar
Thanks Derick! Anyone else? Suggestions on how to set the amps specifically, since my new HU can control all the settings?
Old 12-14-2010, 11:16 AM   #123
Herbicidal
Herbicidal's Avatar
New subwoofer box.
I've decided to replace the vented subwoofer box with a sealed one. I checked the requirments for my 10" Alpine Type R subwoofer and this one fits the bill from Sonic as far as internal box volume. Hey, for the price of a tank of gas, I bought the box and paid the shipping. It's worth it to me to give it a try. Plus it has a smaller footprint than the vented box I have now. AND it has an angled back that I think will fit nicely up against the back of the rear seat. Here's what I ordered for $17.99 plus shipping:
<link to the specs of the sub box>
Old 12-14-2010, 11:21 AM   #124
derickveliz2
Looks nice! Herb...
Please let us know how they compare to the ported box.
D.
CLA 250, 4MATIC
Old 12-14-2010, 11:26 AM   #125
derickveliz2
I was looking at this one, but it's out of stock!
cheap!
CLA 250, 4MATIC
Old 12-14-2010, 11:37 AM   #126
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
I was going to ask why one would pick sealed over ported and googled it and answered my own question. :) Heres what I found:
Sealed Vs Ported Subwoofer Boxes
So you are ready to start building your car audio system? Where to start? Well a good place to begin is with the subwoofer enclosure. There are many types of enclosures for every vehicle and listening style and each has its advantages and dis-advantages. As just a general rule of thumb it is important to make sure your subwoofers will match the chosen enclosure so I recommend knowing what you are planning to run before starting. So for instance before deciding on a subwoofer box you will want to check what the recommended airspace specifications are for that model. Now we will discuss a few different options available for enclosures.
Sealed Subwoofer Boxes:
The most common and versatile type of enclosure is sealed. This style enclosure is ideal for any application where space is going to be an issue. In some cases a sealed recommendation for subwoofer box will be half of what the ported recommendation is. They also have the advantage over ported and band pass enclosures in terms of overall sound clarity. A sealed subwoofer box will deliver a tight, clean and accurate bass response and have a flat frequency response curve. In general a sealed box will be for listeners looking for sound quality driven system that is clean across the entire frequency band.
Vented & Ported Subwoofer Boxes
Next up are ported or vented enclosures, “ported” & “vented” are synonymous, it just means the enclosure has a hole in it to let air escape. You know that guy you can hear from 2 blocks away? Well he is likely running ported box. This style enclosure will likely be about twice the size of a similar sealed box since the airspace inside the chamber is much larger. Ported enclosures are tuned to a certain frequency range which is determined by the port length, width and diameter. The port can be in several configurations such as rounded or a slot which is narrower and taller. Each subwoofer will have a specific frequency they are designed to run at for maximum output. Depending on what you plan to use the enclosure for it can be tuned to various frequency ranges by modifying the port.
In general most competition SPL vehicles tune to high frequencies around 45Hz or higher. This setup would be designed for absolute maximum output but sacrificing a great deal of sound quality. A ported box tuned 25Hz will still allow your system to hit the ultra low bass notes while still keeping sealed like sound quality. The disadvantage is the enclosure will then have a fairly flat frequency range. And then the most common frequency range found usually in pre-built ported / vented enclosures is around 33 – 35Hz. At this frequency the enclosure will still deliver much more bass output than a sealed box but at the same type with still retain most of the sound quality. In other words you will get the best of both worlds with a ported box run at about 33Hz.
Bandpass Subwoofer Boxes
And last but not least are Bandpass enclosures. These are a hybrid box version and combine the features of a sealed and ported sub box into one enclosure. They are generally the hardest to build and design but offer some unique advantages. Bandpass enclosures are all about efficiency. How they work is a subwoofer or subwoofers in some cases are mounted inside a dual chambered box. One chamber is sealed and the other is ported / vented. The sound waves travel from the sealed subwoofer chamber though and out the port. This allows for a much deeper sounding bass and will be tuned to a narrow frequency band which creates a very aggressive sound. Not all subwoofers will work in bandpass enclosure so make sure you research or check the manual first.
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
Rines 15 Yaris Sedan 2008 Marko_ec Central and South America 4 12-15-2008 03:02 PM
