Old 12-24-2010, 12:56 PM   #1
pssrojas
Drives: Toyota Yaris '08
Cheap and Easy Performance Upgrades
Hey guys! Merry Christmas!
I was wondering if there are any cheap mods/upgrades I can do to my '08 Yaris?
Well, I already took out the catalytic converter (legal in my country) and installed an aftermarket muffler/silencer. I was wondering if there are any more simple mods that i can have done to my car?
Well, it's cause I'm still a student and I don't have any solid income yet. So i was wondering if there are any mods i can do to my car for as little cost as possible :P
pssrojas is offline   Reply With Quote
Old 12-24-2010, 01:13 PM   #2
intake/pulleys/header/exhaust/TB swap/remove weight
this is the basic bolt-on setup. after that you get into more expensive projects to make power.
Old 12-24-2010, 01:51 PM   #3
pssrojas
thanks for the info. gonna do some research on those.
Old 12-24-2010, 07:18 PM   #4
jouna
jouna's Avatar
Drives: jdm yaris sedan
1zz injectors are cheap
vvti bregao!
jouna is offline   Reply With Quote
Old 12-24-2010, 08:14 PM   #5
henry33
Drives: yaris1.33
how much will this increase power ? what about mpg?
henry33 is offline   Reply With Quote
Old 12-24-2010, 09:33 PM   #6
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I don't think it gives any HP, but if ur car is running extremely lean(fuel cut off sets in) it might help. But more fuel doesn't mean more HP
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 12-24-2010, 10:31 PM   #7
syntax
syntax's Avatar
MicroImage stickers ! ! ! FTW
Old 12-25-2010, 03:00 AM   #8
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
+1 on the pulleys. The underdrive pulley made good bit of difference on my stock engine. Suspension mods make it lots of fun to drive too.
Old 12-25-2010, 04:45 PM   #9
djct_watt
Drives: 2010 NCP91 5spd
Read my signature. . . but seriously, a good mod is learning to use the search button. It will net you more results. Also try looking for this mystical thing called a "sway bar."
The best modification you can make is between the steering wheel and driver's seat.
Old 12-31-2010, 10:40 AM   #10
whiteyaris
Drives: white yaris
what do you mean by pulleys and TB swap? I'm kinda noob when it comes with these things.
whiteyaris is offline   Reply With Quote
Old 12-31-2010, 11:30 AM   #11
2005rs
Drives: 2005 Echo Rs
read this post: http://www.yarisworld.com/forums/showthread.php?t=9451
use the search function for " throttle body swap "
happy modding!
2005rs is offline   Reply With Quote
Old 12-31-2010, 12:15 PM   #12
This is a pulley:
Old 12-31-2010, 04:00 PM   #13
slow.yaris
Drives: 07 yaris sedan
Between the seat and steering wheel... hmmm
seatbelts? :P
Cheap and easy? Sway bar definitely(rear of course). That and losing weight will make the car more fun than 120 bucks spent any other way. Springs and shocks/struts next but that's not exactly cheap or easy.
slow.yaris is offline   Reply With Quote
Old 12-31-2010, 04:52 PM   #14
djct_watt
Yes, search button! But sway bar is the best bang for the buck!
Old 12-31-2010, 07:34 PM   #15
H3LlIoN
Drives: '09 Yarrrr hatch
This is a pulley:
LIES! Those are lightweight yaris rims.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Fun little cheap mod... "Overtake cam" eTiMaGo DIY / Maintenance / Service 25 03-19-2007 12:15 AM
So I got a cheap inverter and some spare things... eTiMaGo In Car Entertainment + Electronics (audio / video / alarm) 3 02-06-2007 04:51 AM
Power acoustik 2400db - 1800w amp! CHEAP! + 12" sealed spkrman Items for Sale by private party 1 11-27-2006 03:02 PM
