Old 01-05-2011, 11:53 AM   #19
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
My gut makes me think it might be something like the fuel pump relay
im gonna second this one. if the fuel pump relay coil side gets hot and worn, it will have a hard time producing a current thru the coil to get a good enough magnet to pull (or push) the switching side of the relay. when the relay is cooled down enough, current can run easily thru the coil and create a stronger magnetic coil.
we have a problem like this with most little civics with thier main relays, the main relay is also the fuel pump relay.
if you wanted to start with the cheapest part first and go from there, i think the fuel pump relay is your cheapest way to start off with
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
