![]() ![]() Drives: 07 Toyota Yaris Hatch-Back Join Date: Jul 2010
tire pressure
Hey guys, got 1 simple question, how much psi I should have on my 07 H/B tire. I am currently running on 185/60/15 with around 35-39ish psi..is it to much? Cus when I set it to 32psi I feel like the steering wheel feels heavy so Iunno....just curious should I go back to 32? Or should I drop it to around 35ish?
well the manual says it should be at 32 psi.....but I always put around 35 psi...and the car feels ok.....i drive a 08 yaris LB
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
I used to run the stock tires at 45 psi with no problem, and got 42,000 miles out of them. Ran some other tires at 50 psi.
What matters anyway is the max sidewall PSI which is listed on the side of your tire (typically 44psi). The 32 psi figure is just what Toyota recommends. |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
I have an 07 HB and run 32 PSI in front tires and 35 PSI in rear. I have 104,000 miles on rear tires and still not down to wear bars yet. Front gets around 60,000 before replacing.
The more pressure you have in tire the less contact with road. Something to think about in wet weather. |
| Tire pressure | ubospawis | Middle East | 56 | 08-25-2011 07:12 AM |
| Single Tire Replacement - Using Pressure Sensor? | 1stOne | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 09-13-2010 11:25 AM |
| recurring loss of tire pressure | toad | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 12-10-2009 05:54 PM |
| Higher Tire Pressure | captainm27 | General Yaris / Vitz Discussion | 46 | 01-27-2009 11:17 AM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 08:09 PM |
