Old 01-12-2011, 06:13 PM   #1
yaris2010RS
yaris2010RS's Avatar
13 inch?
i dont know if this has been asked before but i did a search (13 inch) and didnt get any hits.
i was wondering if it would be possible to get 13inch(175) winter tires and put them on 13inch rims (with 4x100 bolt pattern) and put them on a yaris.
how badly will this mess up my speedo and/or my entire car? my car has stock 15" alloys on it now, are 13" too big of a difference? are 13" just a bad idea all together? let me know what you think
Old 01-12-2011, 06:16 PM   #2
33OH
Drives: '08 Yaris
As long as you run proper tire sizing (175/70/13), it won't mess up your speedo. But it will be hard to find 13's that will clear the Yaris caliper without some spacers. I would suggest going for 14's, which still may require some spacers depending on the wheel.
Old 01-12-2011, 06:21 PM   #3
yaris2010RS
lol, thanks, i didnt even think about that. 14's it will be then. i wanted to have as much space in the wheel gap as possible cuz my 15's build up alot of snow and slush and it makes them even worse.
Old 01-12-2011, 07:46 PM   #4
True that there aren't a LOT of wheel choices in 13", and the ones I have are wide for racing. They do clear the calipers though.
Old 01-12-2011, 08:03 PM   #5
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i fit 13X9 4" backspace Bassett Racing wheels on my MR2 spyder with no spacers and i'm guessing my front caliper/rotor combo is no smaller than the yaris.
Originally Posted by xnamerxx
you nailed it sir.
Old 01-12-2011, 09:51 PM   #6
I tried a set of 12" Subaru Justy steel wheels as an experiment, and they were less than 1/2" shy of clearing the caliper, so I would think that 13" steelies would be OK.
Old 01-13-2011, 01:23 AM   #7
13's fit, just hard to find a set that'll clear yaris calipers....
you're better off finding some 14" wheels/tires used on kijiji since just about anything with a 4x100 pattern will fit the yaris's small hub center...
tire size be damned...you can run almost any available 14", aside from a 195-65-14 and still be fine in the winter
Old 01-13-2011, 01:42 PM   #8
yaris2010RS
y will 195-65-14 not fit?
Old 01-13-2011, 06:42 PM   #9
too tall
Old 01-14-2011, 02:02 AM   #10
yaris2010RS
but 185-65-14 and 205-65-14 will fit?
Old 01-14-2011, 09:08 AM   #11
33OH
Drives: '08 Yaris
205/65/14 will be WAY too tall. 185/65/14 is fine.
Old 01-14-2011, 10:03 AM   #12
Some education Jeff.
The middle number (65) represents the sidewall height as a percentage of width.
185/65 = sidewall of ~121mm
205/65 = sidewall of ~133mm
Old 01-14-2011, 10:00 PM   #13
Tamago
Tamago's Avatar
Drives: ZZW30
it's a snow tire.. who cares?
but then again, 205 is too wide for a snow tire on a tincan-light yaris
you nailed it sir.
Old 01-15-2011, 02:12 AM   #14
yaris2010RS
lol, i know the middle number was the profile %, it was just the way u said 195-65-14 would not fit, like that certain size was a triangle or square. lol
Old 01-15-2011, 11:32 AM   #15
Viperoni
Drives: 2005 Toyota Echo
FWIW, I have 13x7.5 Lenso's with a 25mm offset as my racing rims for my Echo.
