#415 |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
I couldn't resist not to take a picture on the car with the engine bay looking messy but man Fu*k me I'm happy with this intake already. It looks gorgoues and I hope it feels better than it looks like!
This is estimated to finish this week as I am doing a custom catch can (Finally ! ) , re-routing of the first & last part of the intercooler piping and some minor issues with the exhaust hitting the frame chassis. Prays god this will not give me hard time to settle the engine ones again ..... we have some tuning to re-do! |
#416 |
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
questions...
where did you get that? how can i get one? will it fit under the stock plastic cover? |
#417 |
#418 |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Looks good....
#419 |
i want dyno
#420 |
i like the way it looks
05 Scion tC allmotor 350+ hp 9.34@144mph 05 Scion tC sfwd 880hp 9.96@147mph 05 Scion xB 280hp 12.97@104mph 07 Toyota Yaris 357hp 12.80@107mph |
#421 |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
That is one sexy intake!
05' Echo Hatch - Greddy Supercharger - rear disc |
#422 |
Intake setup was finished today. The engine started and ran without even needing a tune.
Also re-routed water lines and intercooler piping (which I need to re-spray though). The only issue I have is that because of the larger throttle body the idle is at a still on 2000 rpm which is much. The TPS and Idle control connectors match perfectly but I cannot get the idle control work in order to slow idle as I need. The throttle body is of the 2ZZGE used on Celicas and Vibe GT series cars. I would need the car owners manual to check what is the exact frequency of the idle control motor. Also made a stainless custom catch can but still needs to setup the fittings. Next up is the NST crank pulley and we are done! |
#423 |
![]() so nice
#424 |
sweet. its been a long time coming and you are so close. Happy for you man
#425 |
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
zexy!
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
#426 |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
That is one tight engine compartment. All Business! It will make any car owner thinking of running against you, think twice.
#427 | |
![]() Update .. working on a 3 gauge setup of oil pressure/ temp / water temp. Still need to arrange wiring and will post a picture of them as soon as I have time. |
#428 |
Drives: "Burning It Down GTX2860RS XB" Join Date: Sep 2010
Lookin good dude. Thank god your turbo'd, cause I don't think that intake manifod will work right on a N/A cars. Not quite sure it's mathamaticly correct by designe. My buddy Chris at Weapon-R went through two designes before it made power instead of loosing it. Looks good though dude. Enjoy the fruits of your labor.
XBG |
#429 |
^ it's good for a turbo app, looks pretty much like mine. He'll make power in the higher end with it and probably lose some torque in exchange.
Longer runners will make more torque, but you gotta do the math, as xbg said.
#430 |
I do like the color combo. Haven't seen that combo done.
XBG |
#431 | |
BTW I found this on ebay/... I think the problem of the Oil Turbo leak is because I am using a Journal Turbo Fitting instead of Ball Bearing one. |
#432 |
How boost you gonna run?
| Motor Longevity | Pavel Olavich | DIY / Maintenance / Service | 10 | 03-17-2012 11:43 AM |
| cali yaris built motor | cali yaris | Performance Modifications | 83 | 09-03-2009 11:08 PM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 02:43 AM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 10:58 AM |
