![]() Drives: Toyota Will Vi Join Date: Jan 2010
EVAP VSV voltage please
Hi,
my car is based on Yaris mechanicals with the 2NZ-FE engine. I measured the voltage at the EVAP VSV connector with the ignition on and there was 10.5V. Not enough to open the valve reliably. Can someone meter their VSV connector and see if that is normal behaviour please? I'd expect 12V or nothing at all but not anything in between. And if anyone knows when the VSV should or shouldn't be opening, it would be handy to know. Thanks! |
The VSV is pulsed by the ECM and the frequency increases as the RPMs do, so with a DC voltmeter the voltage will be lower at lower RPMs and will approach battery voltage at full throttle.
Many thanks. I tested it by sucking on the pipe with the engine running. Sure enough there was a regular pulse and a taste of fumes.
| Voltage regulator TSA | hirme | DIY / Maintenance / Service | 6 | 10-12-2017 10:58 PM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 02:15 AM |
| Voltage regulator and Amperage question... | cr.chango | DIY / Maintenance / Service | 13 | 11-24-2009 01:59 PM |
| RMS capabilities | Slick | In Car Entertainment + Electronics (audio / video / alarm) | 31 | 08-21-2009 10:52 PM |
| High voltage | -m- | DIY / Maintenance / Service | 7 | 08-01-2007 10:48 PM |
