#19 |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
I have the TRD (Borla version) axle-back on my sedan.
At 60 mph or below I hear nothing inside the car. At 70+ mph or with the addition of passenger &/or cargo to cause extra engine load the pipe is sound quite noticeable. Not unpleasant, but you'll need to crank up the tunes a couple notches.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#20 |
I might try a little experiment this weekend with a Cherry Bomb glasspack, maybe a small turbo muffler. Something short.
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed. |
#21 | |
![]() ![]() Drives: an egg Join Date: Aug 2010
#22 |
Parallel Parking Pro
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#23 | |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
Many thanks in advance! R2 |
#24 |
![]() Drives: yaris hatch back Join Date: Oct 2010
what size is theinlet on the trd exhaust
#25 | |
- yes, it will fit your '09 5dr - yes, it is all stainless steel construction, including welds - in cabin sound is not too loud, it is a very low tone, which does not get whiny or raspy under hard throttle. I waited a long time to get a good deal on a used one, and it was well worth the wait.
#26 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
Nitto is a very low-tone, not too loud exhaust as well.
Not sure on the other points, maybe someone else can chime in. |
#27 |
Crazy Oil Sniffer
Thanks guys I appreciate it.
#28 |
I can't specify the size but... the TRD axle-back bolts directly (replacing the OEM axle-back section) to the stock mid-pipe and uses all the OEM hanger points. It literally takes only one wrench/socket and 10 minutes max. to re & re.
#29 |
Crazy Oil Sniffer
Thanks everyone for the help in this thread. I just installed the Tanabe Medalion Touring exhaust I ordered from Micro Image (Thanks again, Garm!) and I must say it is just perfect. It's aggressive, deep AND quiet enough at the same time. You can hear it well inside the car but it's not intrusive. Exactly what I was looking for. Can't wait to do some more driving!
It's a very high quality piece and very easy to install. Fit is superb. I'm sure the Nitto would have worked well for me too, but ultimately the state of Maine uses 95 db by SAE J-1169 as their standard and since the Tanabe was tested at under 93 db by the same standard I knew I could prove it's legality. Thanks again, everyone! R2 |
#30 |
^ you are welcome, glad we could help out.
#31 |
My TRD axle-back is starting to sound louder now. It likely has close to 70,000 kl. (approx. 45,000 miles) use by now.
| aftermarket exhaust | mark7337 | Performance Modifications | 2 | 05-08-2009 12:51 PM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 10:23 PM |
| anyone use Dynamat/ Be Quiet to deaden exhaust noise? | Galavoxx | Performance Modifications | 9 | 11-29-2006 05:28 AM |
| What aftermarket exhaust will fit the Yaris Sedan? | dngz | Performance Modifications | 2 | 10-02-2006 02:41 PM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 02:13 PM |
