Old 02-08-2011, 03:02 PM   #1
mescalito2
Drives: Yaris 2007
Toyota Yaris handbrake does not work when cruise control is on
Hello there!
My Toyota Yaris 2007 handbrake does not work when cruise control is on.
Am I the only one with that problem?
thanks!
mescalito2 is offline   Reply With Quote
Old 02-08-2011, 03:04 PM   #2
if you're driving along without cruise control (but with your foot on the gas), how well does it work then?
Old 02-08-2011, 04:16 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
Why the hell would you want to use the hand brake while using cruise control???
Old 02-08-2011, 04:20 PM   #4
If you are thinking that the handbrake should cancel cruise, like the foot brake does - It does not.
Old 02-10-2011, 12:22 AM   #5
johnny_vitz
Drives: 2005 Toyota Echo
lol x2
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 02-10-2011, 02:54 AM   #6
frownonfun
frownonfun's Avatar
define "work"
I crush you like tiny clown car, because you are clown, yes?
Old 02-10-2011, 08:59 AM   #7
bkndacn
bkndacn's Avatar
Drives: 2009 Toyota Yaris
I concur with Astroman : why the he'll would you want it to work?!
I got a ride in Garms' Yaris and got on a plane within 24 hours of each other.... his yaris was faster! I bet if he put wings on it he could get passed all that L.A. traffic!
bkndacn is offline   Reply With Quote
Old 02-10-2011, 07:02 PM   #8
mescalito2
Drives: Yaris 2007
because I want to stop. A break is a break! it always should stop your car no matter what.
Old 02-10-2011, 07:12 PM   #9
Chuck G
Drives: 2010 Yaris Sedan
Originally Posted by johnny_vitz View Post
lol x2
Handbrake + Cruise Control = Good Times!!
you guys are missing out!!
Old 02-10-2011, 07:25 PM   #10
mescalito2
Drives: Yaris 2007
Originally Posted by frownonfun View Post
define "work"
frownonfun thanks for you reply. I think I expressed wrong myself. What I mean is: when the cruise control is on and then I use the handbrake the car indeed slows down because the brake works, but the cruise control does not deactivated, therefor the cruise control system detect that the car is slowing down and the engine increase the revolutions to keep the speed up (accelerates). The conclusion is that the handbrake works but the cruise control system tries to keep the speed up therefore the car accelerates even more when the handbrake is on and that is DANGEROUS.
Some people should ask "why don't u use the food brake", and yes of course that is normal... but imagine in case of an hard accident if you push down the "food brake" it will injure bad your foot (that happened to me in the past).
At the end a brake is a brake it should ALWAYS deactivate the cruise control system no matter what.
Thanks!
Old 02-10-2011, 09:43 PM   #11
That's what I thought you were trying to say. The emergency brake is just that - an emergency mechanical backup to the hydraulic brakes. I would suspect that if you did some research, that very few if any cars with cruise have the e-brake as a tertiary cancel for the cruise control.
Old 02-10-2011, 09:55 PM   #12
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
What are you trying to do ? drift in snow? lol
Originally Posted by sw07gt
Old 02-10-2011, 10:35 PM   #13
MadMax
MadMax's Avatar
Might try using the brake instead!
And nothing personal here, but is this your first car? You shouldn't be using your handbrake for anything other than keeping the car in place when its parked or in an emergency when your hydraulic brakes have failed. It is not meant to normally slow or stop the car, and excessive use can make it inoperable if you ever really do need it in an emergency!
And I don't think it is abnormal for the handbrake to not disengage the cruise control. I will try it in my Jeep just to confirm that it is the same way.
And I don't have a clue as to what you are talking about here. What's a food brake? Do you mean the brake pedal you depress with your foot? If so, are you trying to say that you've injured your foot and cannot push it down far enough to stop the car? If so, then you really shouldn't be driving in that impaired physical condition...
Old 02-11-2011, 04:12 AM   #14
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
The popularity of racing games and certain unmentionable movies have created a generation of bad drivers.
Old 02-11-2011, 04:50 AM   #15
Yaross
Yaross's Avatar
Drives: 2006 Yaris HB 5DR
Sirs,
my opinion only, I think mescalito2 has brought an interesting point. we love our yaris so much that we should protect it from bad drivers.
i would really like sir CTScott to verify this, we can get a signal from the parking brake (hand brake / e-brake) switch and tap this to the clutch switch for M/T or park/neutral switch for A/T to cancel cruise control if engage.
you can check it out on the electric wiring diagram of the 2007 manual page 105.
Yaross is offline   Reply With Quote
Old 02-11-2011, 07:53 AM   #16
Vinceb
Drives: 2008 5 Speed Sedan
The parking brake does output some kind of signal, the light on your dash turns on when you raise the lever because it's pressing on a limit switch (probably grounding it or lifting a ground). you would need to tap into this wire, and then splice it onto the same line that comes off your "normal brake" that is going to the cruise module (for the purpose of canceling cruise). You would also want to put a diode in between the 2 of them so you don't back-feed the signal. grab a multi meter and check to see what the signal is - won't be a mod that i'll be doing any time soon.
Vinceb is offline   Reply With Quote
Old 02-11-2011, 07:56 AM   #17
Originally Posted by Yaross View Post
Sirs,
All you would have to do is to join the output of the e-brake switch with that of the brake switch. Still, I contest that it is the wrong thing to do. Cruise control can be canceled by hitting the stalk or by tapping the brake. Your right hand should be on the wheel, where it is in close proximity to the stalk, rather than over by the e-brake.
Pulling the e-brake while driving at cruising speed is ludicrous and is far more likely to result in a serious crash. If the OP has a physical impairment that prohibits he/she from using the brake pedal, he/she should have his/her car properly adapted with hand controls, rather than putting other drivers at risk.
Old 02-11-2011, 08:31 AM   #18
MadMax
MadMax's Avatar
An excellent observation, and one I need to think about considering I have a 13-yr-old who soon will be driving (and is already driving my Jeep offroad) and who is also a heavy gamer. However, luckily he has not shown any bad habits as the result of his video gaming.
Also an excellent point, if the OP has physical limitations that impact his driving of his car, then he should have it properly modified so he can do so. I know a soldier who lost both legs in combat but still wheels a 5-speed Jeep. He built the devices himself, and it is very impressive!
Cheers! M2
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
Cruise Control on 2010 Canadian Manual Kaya B. DIY / Maintenance / Service 25 10-01-2010 04:31 PM
