Old 02-17-2011, 01:31 PM   #19
RedRide
RedRide's Avatar
Originally Posted by brg88tx View Post
all y'all worried about the break in period should also realize that unless your car had 0 miles on it when you bought it, it's likely been on at least 5 test drives and nearly everyone on a test drive floors it to test the car's pickup.
Add to that the car was driven off the assembly line in Japan into a storage lot.
Then driven/loaded onto a carrier to transport it to a dock.
From there, driven/loaded onto a ship bound for America, etc.
Then driven off the ship to another storage lot, then driven onto a car carrier/train car and transported again.
Then, perhaps another car carrier before it reaches your dealer.
As someone who worked at an auto assembly plant in the past, I can tell you the cars are jockied quickly so......
However, these are only brief perieds and there is no reason to add insult to injury and continue the abuse when you get it as parts are still not broken in and damage can still be done.
Also all this loading/ unloading and test drives are not nearly as bad as someone getting a new car and imeadiately driving it from NY to Flordia (for example) and running it at a constant 3k RPM (for example) before any real break in has occured.
Old 02-17-2011, 01:59 PM   #20
RedRide
RedRide's Avatar
Originally Posted by cdydjded View Post
I nor anyone here can intelligently answer that question. None of us are Toyota engineers. I can tell you this, engines today are built completely different than 40yrs ago. Fuels, oil viscosities are all 100 times better than the 1970's. Most engines today are aluminum as opposed to cast iron. We have fuel injection & ECU's that control everything. Cant compare 1970's to now.
Yes but, piston rings and cylinder walls are still cast iron or cylinder walls are plated with a better weaing metal than what is used for the block.
Even if the block is aluminum, it still has a cast iron/plated cylinder sleeve. Bearing and crankshafts for example are still made basically the same
Basically, the only thing made of aluminum are non wear items and critical bearings/mating surfaces are stiil cast iron or steel.
Aluminum an other alloys are used prmarily just to save weight, not for better wear properties.
Granted, oil is much better but, parts still have to wear in to one extent or another.
Capice?
Old 03-02-2011, 12:59 AM   #21
bear4
Drives: 2007 yaris
Why driving at constant 3k RPM is bad? I got my brand new car in GA and drove 5hrs to FL at 3k rpm, did not have any problems...
bear4 is offline   Reply With Quote
Old 10-21-2012, 10:41 PM   #22
Fenanorn
Drives: 2012 Yaris L 5-speed
Go check out the break-in period for a new GT-R. It's like mission impossible.
Fenanorn is offline   Reply With Quote
Old 10-22-2012, 12:26 AM   #23
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
it's a yaris. a stock one at that. don't rly see the point of beating on it?
b20vteg is offline   Reply With Quote
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
90% on short trip. What to do to protect engine? lh59 DIY / Maintenance / Service 22 12-17-2008 09:02 AM
