Old 02-17-2011, 03:34 PM   #649
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
So sad...thanks for the plead for the 5 axis...
annn is offline   Reply With Quote
Old 02-18-2011, 02:34 AM   #650
Astroman
Modded Moderator
Astroman's Avatar
Yes thank you!
Old 02-18-2011, 07:28 AM   #651
SailDesign
Drives: .
+1000 - I loved that little beast when it came out.
Old 02-18-2011, 01:13 PM   #652
Jason@SportsCar
Got some work to do...
Old 02-18-2011, 01:28 PM   #653
and some splainin'!
Old 02-18-2011, 01:32 PM   #654
Looks familiar!
Old 02-18-2011, 01:36 PM   #655
Jason@SportsCar
Looks familiar!
Now I just have to get it in before the race next weekend.
Old 02-18-2011, 01:53 PM   #656
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
what name brand is that u testing out? u used to ran Kaaz right?
Old 02-19-2011, 01:56 AM   #657
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Government sucks ass!
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 02-19-2011, 07:03 PM   #658
Jason@SportsCar
Only two hours to pull the trans this time. :)
Old 02-22-2011, 12:58 PM   #659
Jason@SportsCar
Yaris video number two, JGR MX, is up:
http://www.jgrmx.com/cgr/community/home.htm
http://www.youtube.com/watch?v=I-iTY8DDiuk
JGR NASCAR VS MX:
http://www.youtube.com/watch?v=5XFi4upCcS8
Old 02-22-2011, 01:36 PM   #660
Jason@SportsCar
Since the trans came out so easy - clearly I have had too much practice - I decided to tackle another project, a new steering column. The stock column has a lot of resistance, even with the motor removed, and it is very heavy. So it will be replaced with a splined shaft and couple of heim joints.
Old 02-22-2011, 04:54 PM   #661
^ ooh curious to see how that turns out.
Old 02-22-2011, 05:10 PM   #662
Jason@SportsCar
Being able to pull the parts out of the sedan that was getting crushed is making it easier. I just have to weld up a top mount for the heim joint closest to the steering wheel.
Old 02-22-2011, 07:22 PM   #663
ilikerice
ilikerice's Avatar
ingenuity at its best!
Old 02-22-2011, 08:28 PM   #664
Jason@SportsCar
If anyone is in the Rosamond, Calif. area this weekend we will be racing the Yaris at Willow Springs. Right now there are seven cars in our class, with about 30 in our group.
Best of all, snow in the forecast for Sat.
Camguard Presents
San Diego Cal Club Double Rational
Willow Spring International Raceway
February 26-27,2011
Sanction #11-N-1384-S/11-N-1385-S/11-R-1386-S/11-R-1387-S
Start times are approximate and are provided as a convenience for competitors. It is the competitor's
responsibility to know when their group is on track as the sessions may begin earlier of later,
depending on circumstances
REGISTRATION HOURS
Friday .............3:00 PM to 8:00 PM...........at Track
Saturday.........6:30 AM to 11:00 AM.........at Track
Sunday...........7:00 AM to 9:00 AM ..........at Track
TECH INSPECTION HOURS
Saturday.........Open 7:00 AM...................at Track
Sunday...........Open 7:00 AM...................at Track
Tech stickers will be given out at Registration only to
those Drivers with an annual TECH and 2011 helmet
sticker. Bring your Log Book & helmet to Registration.
All other Drivers must go to the TECH Trailer during
scheduled hours.
RUN GROUPS NATIONAL/REGIONAL
Group 1: SM, PRO7, SPEC 7
Group 2: FA, FB, FC, FE, FM, ASR, CSR, DSR, S2000, CS2000
Group 3: ITA, ITB, ITC, ITS, ITR, SSB, SSC, ST, T1, T2, T3,
SPEC 944, HP,STU
Group 4: SRF, FF, CF, SF.F500, FV, FS, FST
Group 5: GT1, GT2, GT3, SP, GTL, STO, EP
FP, ITE, AS, RS, HC, ASC, MAZDA GT2
REVISED 2-6-11
8:00 A.M. Group 1. 20 Minute Practice
Followed By: Group 2 20 Minute Practice
Group 3 20 Minute Practice
Group 4 20 Minute Practice
Group 5 20 Minute Practice
10 Min. Break
Group 1 20 Minute Qualifying
Group 2 20 Minute Qualifying
Group 3 20 Minute Qualifying
Group 4 20 Minute Qualifying
Group 5 20 Minute Qualifying
1 Hour Lunch
Group 1 18 Laps Race/or 30 min
Group 2 18 Laps Race/ or 30 min
10 Min Break
Group 3 18 Laps Race/or 30 min
Group 4 18 Laps Race/or 30 min
Group 5 18 Laps Race/or 30 min
8:00 A.M. Group 1 20 Minute Practice
10 Min. Break
1 Hour Lunch
Group 2 18 Laps Race/or 30 min
10 Min Break
Old 02-23-2011, 07:05 AM   #665
henry33
Drives: yaris1.33
cool video :)
thanks
henry33 is offline   Reply With Quote
Old 02-28-2011, 01:13 PM   #666
Jason@SportsCar
What a weekend... Freezing temps, burned up tires, contact, great racing.
After the mad thrash to get the OS Giken LSD installed we made it to Willow Springs for the SCCA Double National. Seven cars were registered in H Prod, but only five ran each day. Apparently the threat of nasty weather on Sat kept some of the topless cars away.
This was also our first race using the 13" Goodyear slick mounted on our new Jongbloed Racing wheels. This combo drops about 30lbs of unsprung and rotating mass from the car, and the tires are 3" smaller diameter, which really helps the gearing.
I got the Pole on Sat, and a great start in the race. The Yaris is a completely different animal with the new diff and tires. No more one-leggin coming off of turns, hit the gas and it just pulls. The car also no longer feels like it is going to tip over, thanks to the shorter tires, and the gearing advantage the tires give really makes it accelerate.
Unfortunately, as we thought might be the case the much shorter tire is more heat sensitive than the monster 15"s we were running. About midway in the race the front tires started to give up, and as the last few laps were winding down I could hardly keep it on the track. At the stripe Gary Wittman took the win in his Austin Healey Sprite, I held on for second.
I killed a brand new tire in one day.
For the Sun race I changed to a harder compound Goodyear on the front of the car. Once again I qualified on the Pole. This turned into one of the best races I have had. Wittman and I swapped the lead something like eight times. At about half way Wittman and I entered Turn 1 side by side (a 90 degree left hand sweeper that is taken around 90mph) and made light contact, I got pushed a little wide and put two in the dirt. I kept my foot in it and stayed on him. Luckily the contact was mostly tire to tire, leaving him with a black stripe and me with a yellow sidewall.
The harder compound tire stood up much better, and only started to fade at the very end - Goodyear still has one harder compound we can try next time. It was a very close race but Wittman had just a little more left than me at the end, after a 30 min race we were just over 1 sec apart at the finish, with Wittman first and me second.
Even though we did not win, we are very happy with the changes to the car, it certainly faster and way more comfortable to drive at the limit. This makes four poles, two wins and two seconds so far, and we are leading the Divisional points again.
This event marked the one year anniversary since our Yaris hit the track. In 2010 we lapped Willow Springs at a 1:41.7, now a 1:36.9. Progress.
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 07:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 10:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 05:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 10:51 AM
