Old 02-16-2011, 10:24 PM   #1
yaris srq
Drives: 2007 Yaris Sedan
Lowering Suspension - Performance or Aesthetics
Hi all, new to the forums... I have a stock 2007 sedan and the stock wheels with hub caps are the only thing I don't like about it, so I'm going to buy some new wheels and tires. I see in a lot of threads that people lower their suspension when they get new or larger wheels, is this for a performance or comfort reason, or purely aesthetics? I ask because I actually like the "4x4" look.
Thanks in advance for any info.
yaris srq is offline   Reply With Quote
Old 02-16-2011, 10:30 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Lowering the car to a certain point can provide better stability and assist with cornering. Adding a rear sway bar on the sedan along with the lowering made driving the car for me much more enjoyable as well as handle like a completely different car.
Old 02-16-2011, 11:13 PM   #3
spdfrk
spdfrk's Avatar
Drives: 2010 yaris
I have an '10 hatchback and recently put the complete TRD handling package on (lowering springs, shocks, and rear sway bar and it's great! Virtually no loss in ride comfort and the car looks like it's supposed to (if you didn't know what a stock Yaris looked like as far as wheel-well clearance you would never guess it had been lowered).
What DID make a difference in ride is the 17" wheels I put on; vastly improved steering response and cornering ability but the ride is sacrificed. I'm going to get some nice alloy wheels for the stock 15" tires to use as a winter/long trip set-up. I suppose the happy compromise would be 16" wheels. Hope this helps.
BTW, the TRD springs drop it 1.5" all the way around.
spdfrk is offline   Reply With Quote
Old 02-18-2011, 04:01 AM   #4
cougar65
cougar65's Avatar
Drives: 2010 yaris 5door
i was looking at springs and what is the difference between 3k and 4k... is that the spring load?
cougar65 is offline   Reply With Quote
Old 02-18-2011, 08:58 AM   #5
PumpkinSteve
PumpkinSteve's Avatar
Drives: Yaris SR 1.8
Performance for me, I like to go around corners fast!
PumpkinSteve is offline   Reply With Quote
Old 02-18-2011, 05:57 PM   #6
spdfrk
spdfrk's Avatar
Drives: 2010 yaris
Most likely. I think that's kilograms per centimeter (correct me if that's wrong). If it wasn't metric it'd be lbs. per inch. I like the TRD's because they are progressive (there are other brands that are as well) ; nice soft ride for small bumps and get stiffer as they compress for the bigger ones.
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 10:08 AM
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 04:29 AM
NSW Proposed Suspension Restrictions Bella Australia 0 09-22-2010 02:51 AM
I want stiffer suspension, not so much lowering. goku87 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-26-2009 12:50 AM
