Old 01-30-2011, 09:41 PM   #361
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
....you're still logged in ;)
Had me laughing.
We can seee youuu
Old 01-30-2011, 10:08 PM   #362
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
So I see you want to still play. Lets skip the character bashing and how about you just answer some questions.
1.Why did your tuner release your car running so dangerously lean?
2.Against common knowledge why was your car running so dangerously lean?
3.Why does your power level out at 5200 rpms?
4.Why are you running a aftermarket intake and limiting yourself to 6000 rpms?
5.What is the duty cycle on your fuel injectors running those rpms and boost?
6.Having spent so much money on the engine and having connections throughout the industry why are you running stock valve spring?
7.How did you come up with the fact that your cams have too much overlap when thats controlled by how the cams are degreed?
8.How much total timing do you have dialed in on your combination?
Since I'm the know it all with no knowledge about anything please explain those simple questions for me. No need to bash here and knowledge as to why any of those things are happening would be furthering the knowledge on this forum.
Old 01-31-2011, 06:18 AM   #363
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by Scubaru Steve View Post
xb, yaris, echo, same platform.
elise, celica, may share the same engine, not even close to the same platform.
can you swap suspension? brakes? transmission? list goes on....
its not really a comparison...
actually, the xb/xa/echo is in no way "swappable" with the yaris.. suspension is different, brakes are different, hubs are different, interior (seats) are different, engine management is different (DBW instead of cable throttle)
so, they share most of the same engine.. that's about it. the transmissions don't even swap back and forth without modification. this idea that they're the same platform is wrong.
Old 01-31-2011, 09:48 AM   #364
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
So what about all the guy and gals on this forum with '00-'05 model yaris?
Old 01-31-2011, 02:28 PM   #365
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
Originally Posted by Nexus1155 View Post
HOLY **** he is banned... I didn't think I'd live to see the day that someone more disruptive than Tamago came on this forum
I'd have to disagree.
Old 01-31-2011, 03:55 PM   #366
johnny_vitz
Drives: 2005 Toyota Echo
I think this thread is getting to everybody . I was on scionlife.com and clubxb.com, and it's where I found a bunch of my parts for my car. And now i'm here...all is well as long as we can learn from each other.
Tamago was the one that confirmed for me that the xb trans would fit into my echo (thanks btw), I might not have gotten an answer elsewhere!
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 01-31-2011, 11:21 PM   #367
...this thread is going no where fast
Old 02-01-2011, 06:16 AM   #368
MaineYaris12
Drives: Yaris 2
like the 80% of the threads on here
MaineYaris12 is offline   Reply With Quote
Old 02-01-2011, 10:21 AM   #369
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
I vote to lock it. There is no more useful information being put in.
Yoda is offline   Reply With Quote
Old 02-01-2011, 08:05 PM   #370
Tamago
Tamago's Avatar
Drives: UZJ100
keep it open, so he can keep coming back to defend his tunner's "honner"
Old 02-05-2011, 01:50 AM   #371
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
oh he's banned? i haven't been logging in for a while now, didn't realize so much as happened!
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 02-19-2011, 05:17 PM   #372
turboecho2005
turboecho2005's Avatar
This looks like another case of too much money and not enough smarts... Thats my useless 2 cents :)
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 02-20-2011, 11:59 AM   #373
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Ditto. I just dont care for people who bash others because they are not using top of the line parts. The Yaris is a cheap car and most people here will modify on a budget and be creative with parts. I had a post on my turbo thread from XBG about buying fittings from ace hardware store for my turbo oil drain line. Yes, I guess I could have bought 200$ aeroquip fittings from a hot rod shop like him, but I would rather not put 20,000$ into a 13,000$ car. It just dont make no sense to me.
pimp my yaris is offline   Reply With Quote
Old 02-20-2011, 09:03 PM   #374
xnamerxx
0-60 in slow
xnamerxx's Avatar
But those 5 dollars parts will fail because they aren't anodized and make of super secret special "Aircraft Aluminum".
Some times cheap and dirty works just as well as expensive and clean.
Old 02-20-2011, 10:38 PM   #375
And I would. BUT you won't find me criticizing the budget method. It's ALL good in my book.
Old 02-20-2011, 11:09 PM   #376
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
I'm definitely half way to the 20,000 mark. X(
Old 02-21-2011, 03:43 AM   #377
Nexus1155
Drives: Audi
Went to a fitting place to get an oil drain fitting to mate up to an oil drain flange. Went to a hot rod shop first, asked for aluminum ones, they said no and sent me to this place.
Went to the counter and asked the guy about the fitting there along with hose. He just looks at me and was like THERE IS NO REASON TO USE THOSE ALUMINUM FITTINGS ON CARS. Tosses me a steel one makes the line discounted me and has worked flawless. $8 later instead of.... maybe $50 ???
Old 02-21-2011, 04:09 PM   #378
pimp my yaris
C'est la vie
I have a friend that once worked at a local machine shop on a CNC machine and they produced some aeroquip fittings. He was bragging that they were used on the space shuttle. Then I asked him if that was the reason it kept blowing up in a ball of fire!
Want to build costom turbo kit. Need advice from boosted guys! pimp my yaris Forced Induction Forum 639 09-28-2013 11:26 AM
FS: 2005 Scion xA RS2.0 Turbo uberegg Cars for Sale by private party 40 04-03-2010 11:45 AM
Scion xd turbo PARIS Yaris TS Talk 22 02-26-2010 08:08 AM
Check out the new Scion iQ concept. In the States in 2011/2012 LA Yaris California 9 10-23-2009 08:11 PM
